Coolant catch cans/recovery systems....School me #993919
05/16/11 09:33 PM
05/16/11 09:33 PM
Tucson, AZ
Ramrod39 Offline OP
My New Title
Ramrod39  Offline OP
My New Title
Tucson, AZ
Help me select a coolant overflow system. Some are "recovery" systems with different caps and venting systems, some just hold some coolant, but don't let it flow back to the radiator? Is this right? Please explain my options. Parts recommendations gladly accepted. Thanks.
Re: Coolant catch cans/recovery systems....School me [Re: Ramrod39] #993920
05/16/11 09:49 PM
05/16/11 09:49 PM
Kirkland, Washington
Pacnorthcuda Online boogie
Pacnorthcuda  Online Boogie
A "recovery" system will have the hose enter at the bottom of the tank (at least usually). That way it (the radiator/engine) can suck coolant back out.
You then use a recovery rad cap that has the little dime size metal 'button' on the seal side (the part below the big spring). That little button will allow the flow back into the rad under really light vacuum conditions (when the coolant is starting to cool and contract).
Very effective--you want it.
Re: Coolant catch cans/recovery systems....School me [Re: Pacnorthcuda] #993921
05/16/11 10:14 PM
05/16/11 10:14 PM
What Pac said. Top off the rad neck to the brim of the inside lip where the cap seats. You're wanting to get all the air out of there. No magic just pick the type/shape/color of bottle that suits you/looks good. I have a 2 liter plastic pepsi bottle on a DD w a hose to the bottom, a lever stant recovery cap, works fine. When an inventor patented it (then sold it to the car companies) it's selling point was that the elim of air pockets gave more uniform cooling and lowered temps as much as 10 deg (F) and less oxygen from losing the pockets slowed rust development
Re: Coolant catch cans/recovery systems....School me [Re: Ramrod39] #993922
05/16/11 11:13 PM
05/16/11 11:13 PM
Dandridge TN
Dabee Offline
Dabee  Offline
Dandridge TN
I use a JAZZ over flow bottle. I run the hose from the radiator to the drain on the bottom of the JAZZ bottle and just leave valve open. Works just like a factory recovery system.
Re: Coolant catch cans/recovery systems....School me [Re: Dabee] #993923
05/16/11 11:41 PM
05/16/11 11:41 PM
Correct, you need the bottle vented at the top
Re: Coolant catch cans/recovery systems....School me [Re: RapidRobert] #993924
05/16/11 11:47 PM
05/16/11 11:47 PM
Rancho Cordova, CA
Exit1965 Offline
Exit1965  Offline
Rancho Cordova, CA
I picked one up from Autozone. Was tired of the car taking a leak when hot and didn't like the look of a beer can
It's hard to see, but the clear tubing goes to the bottom on the left side.
Re: Coolant catch cans/recovery systems....School me [Re: Ramrod39] #993925
05/16/11 11:50 PM
05/16/11 11:50 PM
South San Francisco, Californi...
MidPenMopar Offline
Looking for fun? Keep looking
MidPenMopar  Offline
I bought a cool aluminium cylinder type at a swap for $20 and it not only works good but looks neat too! You just need to attach it and plumb it with some rubber hose.
Re: Coolant catch cans/recovery systems....School me [Re: MidPenMopar] #993926
05/17/11 01:15 AM
05/17/11 01:15 AM
Tucson, AZ
Ramrod39 Offline OP
My New Title
Ramrod39  Offline OP
My New Title
Tucson, AZ
So I want a bottle with a vent on the top and a "recovery' type cap. The bottle I was looking at (the one that might fit) is 20oz capacity. I worry that a full to the brim radiator will discharge more than 20 oz and spit coolant out the vent. Valid concern?
Also not sure about my cap. I ran the car with a Stant lever cap (model 331) and when I shut it down a bunch of coolant puked out but the upper radiator hose was not hard (no pressure) Maybe it had relieved the pressure before I squeezed the hose? Not sure.
Re: Coolant catch cans/recovery systems....School me [Re: Ramrod39] #993927
05/17/11 01:36 AM
05/17/11 01:36 AM
Rogue River, OR
Jeremiah Offline
Jeremiah  Offline
Rogue River, OR
There are some reasonable aluminum units at summit racing. I just use mine as a puke tank in case of overheating...
Re: Coolant catch cans/recovery systems....School me [Re: Jeremiah] #993928
05/17/11 05:50 PM
05/17/11 05:50 PM
QLD Australia
Keith Black® Offline
QLD Australia
... mounting above/below radiator cap height ok...?
Darren Beale
Keith Black Racing Engines®
Re: Coolant catch cans/recovery systems....School me [Re: Ramrod39] #993929
05/17/11 09:11 PM
05/17/11 09:11 PM
20oz capacity is plenty. Only a high-schooler pukes more than that.
Caps vary in pressure...around 7 pounds is light, around 15 pounds is 'heavy'. Higher pressure raises the boiling point, but it also stress-tests the radiator more.
Again---you want the cap with the button, you can get the lever too.
MOST caps nowadays ARE coolant recovery, with the button.
On my 70'cuda I am using the windshield washer bottle as the coolant tank--works perfect.
Re: Coolant catch cans/recovery systems....School me [Re: Ramrod39] #993930
05/17/11 09:14 PM
05/17/11 09:14 PM
utah
jjl Offline
jjl  Offline
utah
magnum beer can?
formally orangemonster
Re: Coolant catch cans/recovery systems....School me [Re: Keith Black®] #993931
05/17/11 10:09 PM
05/17/11 10:09 PM
Any location (height) will work good.
Re: Coolant catch cans/recovery systems....School me [Re: RapidRobert] #993932
05/18/11 09:15 AM
05/18/11 09:15 AM
Maryland
cudaboone Offline
cudaboone  Offline
Maryland
I have a small aluminum round catch can and it has never returned any coolant to the radiator.. I have the hose going from the top of the radiator to the bottom of the can and a hose from the top of the can down to the bottom of the rad support. It is a b cool radiator with the b cool radiator cap.
Re: Coolant catch cans/recovery systems....School me [Re: Ramrod39] #993933
05/18/11 02:30 PM
05/18/11 02:30 PM
Rio Linda, CA
John_Kunkel Online content
John_Kunkel  Online Content
Rio Linda, CA
The key to recovery is the cap, recovery systems use a cap with a "dangling disc" center valve while the standard system has a valve that is spring-loaded. Also, the cap gasket must seal tight against the neck or there won't be enough vacuum to recover the fluid.
