Rims needed - 5 on 5-inch. 1972 Imperial #993846
05/16/11 08:59 PM
05/16/11 08:59 PM
Tennessee
WyleECoyote Offline OP
Tennessee
There's not too many 5-inch patterned rims that show up here; I'd like to find some Torq Thrusts or old style 5-slot mags for my 1972 Imperial.
Can anyone recommend some "other" sites like Moparts.com that I can go scavenge for rims for sale?
Thanks for your inputs!
Ron
Wile E. Coyote
Super Genius, Lover of FCA US LLC Products
68 Road Runner (440 4-spd), 71 Superbee (383 slap), 71 Charger 500 (383 4-spd wA/C 1of 182), 72 Imperial, 74 Charger SE (440 sunroof), 84 D350 Crew-cab Dually (440), 75 D300 Dually Tandem (318 4-speed)
Re: Rims needed - 5 on 5-inch. 1972 Imperial [Re: WyleECoyote] #993847
05/16/11 09:04 PM
05/16/11 09:04 PM
Garden Grove, CA
OzHemi Offline
Penguin-hating Ginger
OzHemi  Offline
Garden Grove, CA
Try swap meets...I see plenty of 5 on 5 stuff out there. Chevy trucks used that bolt pattern from 1971 until 1998 pretty much on thier half ton 2 wheel drive trucks.
Re: Rims needed - 5 on 5-inch. 1972 Imperial [Re: OzHemi] #993848
05/16/11 09:12 PM
05/16/11 09:12 PM
chicagoland,usa
buildanother Offline
chicagoland,usa
Some GM fullsize wagons and such too in mid to late seventies. I don't know about center register hole size.
Re: Rims needed - 5 on 5-inch. 1972 Imperial [Re: buildanother] #993849
05/16/11 09:22 PM
05/16/11 09:22 PM
Tennessee
Tennessee
Hmmmm....
I didn't think about the center register...
Thank you.
I'll make sure I measure that on one of my rims and on the applicable parts of the car so I know the measurements. Thank you!
Wile E. Coyote
Re: Rims needed - 5 on 5-inch. 1972 Imperial [Re: WyleECoyote] #993850
05/17/11 11:58 AM
05/17/11 11:58 AM
Grand Haven, MI
patrick Offline
patrick  Offline
Grand Haven, MI
yup. 2wd chev trucks are 5x5, as are GM B bodies, including the '94-96 impala SS.
check out the centerline wheels website for overstock...
something in the 6-12mm+ offset (so 4.75-5" backspace for an 8" rim) should work....
these are $160/ea for forged 17x8's(!)
http://centerlinewheels.com/wheel_deals_detail.php?id=13113&type=bolt&data=5-5.0
these are about $100 more
http://centerlinewheels.com/wheel_deals_detail.php?id=12426&type=bolt&data=5-5.0
for the size of the car, some 17's or 18's with tire sizes used on the LX cars (which are ~28-29" tall) would look about right...
2017 Grand Cherokee Overland
Re: Rims needed - 5 on 5-inch. 1972 Imperial [Re: patrick] #993851
05/17/11 12:05 PM
05/17/11 12:05 PM
Garden Grove, CA
OzHemi Offline
OzHemi  Offline
Garden Grove, CA
He mentioned about wanted either TT's or slots, that is why I had said about a swap meet..
(if billet wheels were on the list, lots of that stuff out there too, especially from lowered truck guys that keep up dating from 17" to 20" ,etc. And 15" 2 piece billet stuff is worth nothing anymore,I've bought a bunch of them to sell in Oz, and can find them at the swap meets for $100 a set no problem at all)
Worth looking around in Craigslist too, slots seem to turn up on there too.
Re: Rims needed - 5 on 5-inch. 1972 Imperial [Re: patrick] #993852
05/17/11 12:28 PM
05/17/11 12:28 PM
DELAWARE
bee71mopar Offline
bee71mopar  Offline
DELAWARE
I have the Tomohawk series 20 in. "Sniper"rims and love'm very light weight for that big of a rim also.The one thing I dont like about them is I have to use the stick on weights.Oh and the rubber O-rings that hold the center caps rotted b4 I could put them on the car.Just from sitting on the shelf for about a year and the front ones just barely fit.
Re: Rims needed - 5 on 5-inch. 1972 Imperial [Re: OzHemi] #993853
05/17/11 09:44 PM
05/17/11 09:44 PM
Tennessee
Tennessee
Oz - WOW! Great idea about the 17-inch folks upgrading! And the 15-inch 2 piece billet I'm not familiar with so I'll have to research that. YOu say to "sell in Oz"... can you educate me on how to "shop in Oz"?. Thanks for the ideas!
Wile E. Coyote
Re: Rims needed - 5 on 5-inch. 1972 Imperial [Re: WyleECoyote] #993854
05/17/11 10:12 PM
05/17/11 10:12 PM
Garden Grove, CA
OzHemi Offline
OzHemi  Offline
Garden Grove, CA
I ment that I buy them here and ship them to Australia to sell them. (since I am loading containers anyways, works out well)
On the 15" stuff....like all the old style Boyds,Eagles, etc that are out there. Easy to move the back spacing if need be as well.
Another option...if you find a set cheap that are 5 on 4.75 bolt pattern (Chevy car) you could redrill/insert them to 5 on 5 in most cases too. (if you got the wheels cheap enough to make that worth while)
Re: Rims needed - 5 on 5-inch. 1972 Imperial [Re: OzHemi] #993855
05/17/11 11:06 PM
05/17/11 11:06 PM
Cruising!
Q
QuickDodge Offline
QuickDodge  Offline
Q
Cruising!
The 5x5 bolt pattern is found on SOME full size GM rear wheel drive cars. This pattern was used from at least the early 1970's to the 1996 model year. From 1977-1996 the cars with the 5x5 bolt pattern typically had 12 inch front brake rotors. (as opposed to 11 inch rotors on other models) Station wagons generally had the larger bolt pattern wheels. The biggest models, such as the Olds 98 and the Buick Park Ave. and nearly all Cadillacs have the larger bolt pattern wheels. (The olds 88 and Buick LeSabre have a slightly shorter wheelbase and the small bolt pattern) Police cars are another good donor for the 5x5 pattern.
I have never tried to fit any of these wheels on an Imperial, so I have no idea if these wheels would be suitable.
Re: Rims needed - 5 on 5-inch. 1972 Imperial [Re: WyleECoyote] #993856
05/17/11 11:28 PM
05/17/11 11:28 PM
Southern CA
Colin Frolick Offline
Southern CA
i've been looking at 17x8" wheels for my '71 imp. i probably will get some cheap black steelies. there are actually quite a few available in 5x5. check for example summit's wheel selection narrowed to 17x8 and 5 on 5"... it's good that they list the center bore sizes for the wheels.
http://www.summitracing.com/search/Depar...cAsc&RC=100
the hub on my '71 is ~3.05", and i talked to a place about getting aluminum hub centric rings made. they advised to go with around a 4" hole so the ring would be ~1/2" thick; easier to machine and sturdier. then i think a 235/65-17 tire will fit.
cheers
Re: Rims needed - 5 on 5-inch. 1972 Imperial [Re: Colin Frolick] #993857
05/18/11 11:15 PM
05/18/11 11:15 PM
Tennessee
Tennessee
From "feets" here on Moparts:
(I'm thinking these are 17's or greater??)
Wile E. Coyote
Re: Rims needed - 5 on 5-inch. 1972 Imperial [Re: WyleECoyote] #993858
05/18/11 11:25 PM
05/18/11 11:25 PM
Garden Grove, CA
OzHemi Offline
OzHemi  Offline
Garden Grove, CA
His Smoothie II's are 18"
Re: Rims needed - 5 on 5-inch. 1972 Imperial [Re: WyleECoyote] #993859
05/19/11 12:00 AM
05/19/11 12:00 AM
Canada
CrAzYMoPaRGuY Offline
Canada
Why is everybody overlooking the obvious?
JENSEN INTERCEPTOR is a 5x5 bolt pattern!
CrAzYMoPaRGuY
