516 heads #993725
05/16/11 06:14 PM
05/16/11 06:14 PM
Alaska
73rrak Offline OP
73rrak  Offline OP
Alaska
What are they? Are they any good? I just found a set in a parts car. They look like closed chambered heads. Should they have hardened seats ?
Re: 516 heads [Re: 73rrak] #993726
05/16/11 06:15 PM
05/16/11 06:15 PM
Riverside, Ca
G_bob Offline
G_bob  Offline
Riverside, Ca
67 low flow heads. Won't have hardened seats if still original.
Re: 516 heads [Re: G_bob] #993727
05/16/11 06:31 PM
05/16/11 06:31 PM
Alaska
73rrak Offline OP
73rrak  Offline OP
Alaska
Thank you
Re: 516 heads [Re: 73rrak] #993728
05/16/11 06:45 PM
05/16/11 06:45 PM
MOPAR HEADQUARTERS IN ALDEN NY
hemigod426 Offline
hemigod426  Offline
there are the same closed chamber as the 915 hp 440 heads, just they have small 1.60 exhaust valves, with seats and 1.74 valves installed same power as the 915s,with 2.14/1.81 valves installed they make huge power, if your gunna do iron heads they great heads and cheap. i get 100-200 per set complete
MOPAR OR NO CAR
Re: 516 heads [Re: hemigod426] #993729
05/16/11 07:17 PM
05/16/11 07:17 PM
Akron, Ohio U.S.A.
roadhazard Offline
roadhazard  Offline
Akron, Ohio U.S.A.
WRONG!
The 516 heads have a port shape more similar to the 452 casting. Only the 906 & 915 share the same port shape.
If you can get those to perform better than my 915's I'll buy them off of you
Re: 516 heads [Re: 73rrak] #993730
05/16/11 08:33 PM
05/16/11 08:33 PM
oklahoma
forphorty Online content
forphorty  Online Content
oklahoma
Re: 516 heads [Re: 73rrak] #993731
05/16/11 08:43 PM
05/16/11 08:43 PM
Florida STAYcation
dOoC Online penguin-006
The village idiot's idiot
dOoC  Online Penguin-006
Florida STAYcation
They are a decent head for a streeter/cruiser. Do you HAVE TO HAVE hardened seats? ..I would say no if you are not going to be using it uNder a high load situation like towing a car trailer or something like that.
Re: 516 heads [Re: 73rrak] #993732
05/16/11 09:51 PM
05/16/11 09:51 PM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
they will work but you'll need to have them worked. Stock units are good for a stockish build.
Coming soon!!!!
Re: 516 heads [Re: roadhazard] #993733
05/16/11 09:54 PM
05/16/11 09:54 PM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
WRONG!
my old 516's flowed 260/180???? not bad
