Re: 516 heads
[Re: G_bob]
#993727
05/16/11 06:31 PM
05/16/11 06:31 PM
Posts: 340 Alaska
73rrak
Alaska
Re: 516 heads
[Re: 73rrak]
#993728
05/16/11 06:45 PM
05/16/11 06:45 PM
Posts: 2,315 MOPAR HEADQUARTERS IN ALDEN NY
hemigod426
there are the same closed chamber as the 915 hp 440 heads, just they have small 1.60 exhaust valves, with seats and 1.74 valves installed same power as the 915s,with 2.14/1.81 valves installed they make huge power, if your gunna do iron heads they great heads and cheap. i get 100-200 per set complete
MOPAR OR NO CAR
Re: 516 heads
[Re: hemigod426]
#993729
05/16/11 07:17 PM
05/16/11 07:17 PM
Posts: 3,675 Akron, Ohio U.S.A.
roadhazard
Akron, Ohio U.S.A.
WRONG! The 516 heads have a port shape more similar to the 452 casting. Only the 906 & 915 share the same port shape. If you can get those to perform better than my 915's I'll buy them off of you
Re: 516 heads
[Re: 73rrak]
#993731
05/16/11 08:43 PM
05/16/11 08:43 PM
Posts: 30,253 Florida STAYcation
dIc dOc Deity !
The village idiot's idiot
Florida STAYcation
What are they? Are they any good? I just found a set in a parts car. They look like closed chambered heads. Should they have hardened seats ?
They are a decent head for a streeter/cruiser. Do you HAVE TO HAVE hardened seats? ..I would say no if you are not going to be using it uNder a high load situation like towing a car trailer or something like that.
Re: 516 heads
[Re: roadhazard]
#993733
05/16/11 09:54 PM
05/16/11 09:54 PM
Posts: 24,562 Brookeville, Md
Mr.Yuck
Brookeville, Md
my old 516's flowed 260/180???? not bad
