Moroso crank pulley question #993713
05/16/11 06:02 PM
05/16/11 06:02 PM
Florida-West Coast
Thor500 Offline OP
Thor500  Offline OP
Florida-West Coast
The Moroso crank pulley has the one offset hole like a stock pulley, my balancer holes are evenly spaced, will leaving the one bolt out cause me any grief down the road? Will things be out of balance without it? Or should I "glue" the bolt in the hole, or am I being to anal? Opinions please.
Re: Moroso crank pulley question [Re: Thor500] #993714
05/16/11 07:17 PM
05/16/11 07:17 PM
On the parachute mount
N
n20mstr Offline
n20mstr  Offline
N
file or drill out the hole and put the bolt in
....BAD A$$ STREET CAR.....
Re: Moroso crank pulley question [Re: Thor500] #993715
05/16/11 07:39 PM
05/16/11 07:39 PM
Locomotion Offline
Locomotion  Offline
On my race car I run it with the 3 every-other-bolts that do line up. I've checked them a few times without any signs of loosening, but you can always use blue Loctite as extra insurance.
Less rotating weight! I can be pretty anal too.
Re: Moroso crank pulley question [Re: Locomotion] #993716
05/16/11 08:21 PM
05/16/11 08:21 PM
Florida-West Coast
Thor500 Offline OP
Thor500  Offline OP
Florida-West Coast
I was 2 seconds away from doing that but got the grinder out and had at it, it's ugly but it's on!
Re: Moroso crank pulley question [Re: Thor500] #993717
05/16/11 08:22 PM
05/16/11 08:22 PM
Greenville, South Carolina
BBLM23 Offline
BBLM23  Offline
I use 4 bolts...
Walter
1969 Dart Swinger w/ARC Pump Gas 493 B1/BS 10.18 at 130mph
Racing Pro in street trim.
1981 Aries ARC 548 B1 8.88 at 147mph (footbraking)
1996 Ram 2500 V10 16.52 at 80mph
1981 Reliant 400
Re: Moroso crank pulley question [Re: Locomotion] #993718
05/16/11 08:22 PM
05/16/11 08:22 PM
Florida-West Coast
Thor500 Offline OP
Thor500  Offline OP
Florida-West Coast
Check out the pulley I took off, talk about getting lucky!
Re: Moroso crank pulley question [Re: Thor500] #993719
05/16/11 11:53 PM
05/16/11 11:53 PM
Indy
joshking440 Offline
Lunch is on me!
joshking440  Offline
Lunch is on me!
Indy
Find a buddy with an end mill, and make it fit, or use a grinder, I used an end mill
Re: Moroso crank pulley question [Re: Thor500] #993720
05/17/11 12:06 AM
05/17/11 12:06 AM
Az
Crizila Offline
Crizila  Offline
Az
Holy bat, crap man!!!
Fastest 300
