What's going on with the interior lights? #993696
05/16/11 04:55 PM
05/16/11 04:55 PM
NW Ohio
6pkaar Offline OP
6pkaar  Offline OP
NW Ohio
My son has a 2001 Jeep Wrangler and his interior lights come on when he makes a left hand turn....go out when the car is going straight again. What's up?
Re: What's going on with the interior lights? [Re: 6pkaar] #993697
05/16/11 04:56 PM
05/16/11 04:56 PM
Cincinnati, Ohio
Challenger 1 Offline
Cincinnati, Ohio
Sounds like his flux capacitor is going out.
Re: What's going on with the interior lights? [Re: Challenger 1] #993698
05/16/11 06:39 PM
05/16/11 06:39 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
Door switch?
Re: What's going on with the interior lights? [Re: 6pkaar] #993699
05/16/11 09:04 PM
05/16/11 09:04 PM
Maryland
GO_Fish Offline
GO_Fish  Offline
Maryland
Sure sounds like something in the steering column. Is his left turn signal on when this happens, or happens every time the wheel is turned left with the signals off?
I did have a '78 Magnum, where the interior lights would come on when you pressed the brake pedal (and the brake lights did not work). Turned out to be a bad fuse in the brake light circuit, happened more than once. Replaced the fuse and brake lights worked normally.
Could be the door switch also if the door is loose/ wiggling. Has he had the doors off recently?
Scott B. "I'm a self-made man... I started with nothing, and I still have most of it!" 68 360 rusty B'cuda 'vert (GO Fish)13.59@ 98.72 mph 69 340 GTS stock 14.18@ 95.60 mph 01 5.9L Ram 1500 Quad Cab 4x4 01 3.5L 300M 16.23@ 86.97 mph
