Compression question #993627
05/16/11 02:38 PM
05/16/11 02:38 PM
Texas
GTS440 Offline OP
GTS440  Offline OP
Texas
I have a .030 over 440 with flat top pistons .065 in the hole. I can run a set of
915 ( 78cc combustion chamber I think ) with a .019 compressed head gasket
& have a static compression ratio of 10.27. Is this to much compression for 92
Octane fuel? I also could use my MP " 452 " aluminum heads ( 84cc ) with a
.039 compressed head gasket but my compression would drop to 9.35. Engine
Is for a 65 satellite @ 3700 pounds with max wedge manifolds & 2.5 inch exhaust.
Is 10.27 to much compression for 92 octane with cast iron heads? Or will I make
More power with the better flowing aluminum heads with less compression? Any comments or suggestions appreciated. Thanks, GTS
Re: Compression question [Re: GTS440] #993628
05/16/11 02:48 PM
05/16/11 02:48 PM
Florida STAYcation
dOoC Offline
The village idiot's idiot
dOoC  Offline
Florida STAYcation
If you have a big-gear in the car .. the 915's should be fine.
Re: Compression question [Re: dOoC] #993629
05/16/11 02:52 PM
05/16/11 02:52 PM
Texas
GTS440 Offline OP
GTS440  Offline OP
Texas
Planning on running 3.55 gears.
Re: Compression question [Re: GTS440] #993630
05/16/11 02:55 PM
05/16/11 02:55 PM
Florida STAYcation
dOoC Offline
dOoC  Offline
Florida STAYcation
A 3.55 gear IMO is a middle-of-the-road gear ..... I might go in the direction of the 915's with the comp gasket.
Re: Compression question [Re: GTS440] #993631
05/16/11 02:55 PM
05/16/11 02:55 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Gonna make a difference what cam and the specs on
it(when the intake closes)
Re: Compression question [Re: dOoC] #993632
05/16/11 03:23 PM
05/16/11 03:23 PM
Texas
GTS440 Offline OP
GTS440  Offline OP
Texas
The .039 gasket drops compression to 9.83 is this suitable for 92 octane with 3.55 gears? I don't know enough about cams to make a good call. Where is the best place to educate myself on cams?
Re: Compression question [Re: GTS440] #993633
05/16/11 03:36 PM
05/16/11 03:36 PM
U.S.S.A.
JohnRR Online rolleyes
JohnRR  Online Rolleyes
U.S.S.A.
You have no Quench , try to keep your compression 9.5.
I think some of your numbers are off , the std for steel shim gaskets are .021 and Are you sure of the CC of that head ? I just CC'd a pair of 915's , approximately .025 decked and they measure ~81cc.
I just plugged in numbers , .021 gasket and your 78 cc I get 10.1, if you go to a composite , like the felpro 8519 which is .041 you'll have 9.5 , since you don't have quench anyway that would be the way to go given the parts you have.
Re: Compression question [Re: GTS440] #993634
05/16/11 03:39 PM
05/16/11 03:39 PM
If I was you I would shoot for 9.5 to 1 max on a iron headed pump gas motor The heat and humidity can raise hail with the tune up from spring, summer and fall in most places in Texas Way better to be safe than sorry If you switch to a aluminum head then raise the compression up to 10.0 to 1 to 10.7 to 1 with a big cam, 250 + degrees at .050 valve lift Go to KB pistons web site and use thier dynamic and mechanical on line compression calculator to see the effects of the cam on the dynamic compresson ration, put in a small cam, a meduim cam and then a big cam. You will need the intake valve closing degrees after bottom dead center plus so many degrees( I can't remember exactly how many now ) they ask you to add onto that event. Bigger (more degrees at .050) lower the dynamic compression ratio Is there ethanol in your gas now? If not can you be sure that it will not be added to your pump gas later? I've made 500 + HP on CA pump gas with 10% ethanol in a 440 bored .060 with 906 heads a bunch of times with less than 9.5 to 1 mechanical compression ratio, you can too
Re: Compression question [Re: JohnRR] #993635
05/16/11 04:00 PM
05/16/11 04:00 PM
Texas
GTS440 Offline OP
GTS440  Offline OP
Texas
I will try to cc my heads tomorrow, Tball tonight
