fuel line size #993607
05/16/11 01:57 PM
05/16/11 01:57 PM
desomod Offline OP
desomod  Offline OP
I am looking for a replacement for the 5/16 (I think) line that runs from the outlet of the fuel pump, filter and to the distribution block of a Hemi fuel line. I would like to replace it with a 3/8 line. That would also require a 3/8 inlet/outlet filter with the return line and a diffrent distribution block where the lines split off to the dual carbs. Does someone make a kit??
Re: fuel line size [Re: desomod] #993608
05/16/11 03:16 PM
05/16/11 03:16 PM
Niles , Ohio
therocks Online content
therocks  Online Content
Niles , Ohio
I think Fine Lines makes them.Depends on the car.There is another company that makes lines also but I cant remember the name.You could just get some bulk tuming and make them.Unless its a 100 point resto thats the cheapest route.Rocky
Chrysler Firepower
Re: fuel line size [Re: desomod] #993609
05/16/11 03:28 PM
05/16/11 03:28 PM
Cincinnati, Ohio
Challenger 1 Offline
Cincinnati, Ohio
IMO it's not worth it, I'd stay with stock line sizes because getting all the right size fittings is gonna be tough. What matters is before the pump on the suction side, not the discharge size.
Re: fuel line size [Re: Challenger 1] #993610
05/16/11 04:01 PM
05/16/11 04:01 PM
desomod Offline OP
desomod  Offline OP
It is all 3/8 from the tank to the pump. It sure seems like a potential bottle neck from the pump to the distribution block to have 5/16. From the distribution block to the carbs the 5/16 is ok. I would bend my own lines but still need to find the right filter. The motor is a 528" Hemi with 494 RWHP, I figured this would be something someone else already figured out.
Re: fuel line size [Re: desomod] #993611
05/16/11 05:31 PM
05/16/11 05:31 PM
Cincinnati, Ohio
Cincinnati, Ohio
I hear you and I'm sure someone has, somewhere. The suction should always be bigger than the discharge, on any pump system of almost any kind. You ready to go bigger on the suction side?
I'd it drive first and see and I bet it won't slow you down at all.
Re: fuel line size [Re: Challenger 1] #993612
05/16/11 10:03 PM
05/16/11 10:03 PM
desomod Offline OP
desomod  Offline OP
Why is it that the discharge side needs to be smaller than the low pressure suction side??
Re: fuel line size [Re: desomod] #993613
05/16/11 10:24 PM
05/16/11 10:24 PM
Cincinnati, Ohio
Cincinnati, Ohio
Because gasoline is very hard to suck. If you go bigger on the outlet of your pump, then to get the full benifit, then you need to increase the inlet size.
Any (electric or mechanical)fuel pump for a engine, needs a larger suction line than discharge, no exceptions.
Do guys do it differently, yes. Does it make it right NO!
The short distant from the engine mounted fuel pump to the carbs is very short, so 5/16" line will carry the load in most cases. If it's not big enough, then the suction side isn't big enough either.
Fuel delivery is my specialty, for a long time now.
Re: fuel line size [Re: desomod] #993614
05/16/11 10:31 PM
05/16/11 10:31 PM
It is all 3/8 from the tank to the pump. It sure seems like a potential bottle neck from the pump to the distribution block to have 5/16. From the distribution block to the carbs the 5/16 is ok. The motor is a 528" Hemi with 494 RWHP
, I'd have 3/8 from the mech pump to the carb dist block
Re: fuel line size [Re: Challenger 1] #993615
05/16/11 10:31 PM
05/16/11 10:31 PM
desomod Offline OP
desomod  Offline OP
Thanks Challenger. I was figuring any restriction reduction on the delevery side would help.
So, on a Mopar fuel pump the outlet side, when you remove the barb and look into the port, is a pretty small diameter. By drilling it out to enlarge it would not result in better fuel flow? (I do realise that there is probably alot of engineering there).
Re: fuel line size [Re: desomod] #993616
05/16/11 10:42 PM
05/16/11 10:42 PM
Cincinnati, Ohio
Cincinnati, Ohio
Cool,
Like I said, I'd run it and find out.
And NO I wouldn't run modified fittings.
I know it cost money to buy the fittings and hopefully only do it once.
I'm just telling you what I learned by actually racing and burning fuel. Lot's of racing fuel.
I've also driven my street cars hard off rd and know what it takes.
Moving gasoline is the same no matter what.
Re: fuel line size [Re: Challenger 1] #993617
05/16/11 10:50 PM
05/16/11 10:50 PM
A collage of whims
topside Offline
topside  Offline
A collage of whims
540HP Street Hemi here, the stock line from mech pump to T to carbs has not been a problem to 7500RPM.
That said, the car runs 1/2" from tank/filter/elect.pump to the mech pump.
I prefer to filter the fuel before the pump(s).
