Fired the new stroker. How many miles to break in?
#993548
05/16/11 12:09 PM
05/16/11 12:09 PM
Posts: 834 Beavercreek, Ohio
OA5599
Beavercreek, Ohio
We were able to get the 418 together this weekend, get it in the car, and break in the cam. Good pressure, stays cool, no leaks. Sounds radical and is a torque monster from what we have felt. Took it out a couple of times for total of about 15 miles. Going to Mo-Power on Friday. How many break-in miles between now and then to be safe? What should be my RPM limit until then? Thanks, P.S. Bear with us, but we could have a lot more posts/questions in the following week. Thanks to all who have chimed in with all of the help to this point. ![](/ubbthreads/images/graemlins/thumbs.gif)
Re: Fired the new stroker. How many miles to break in?
[Re: OA5599]
#993549
05/16/11 12:33 PM
05/16/11 12:33 PM
Posts: 5,080 organ
maximum entropy
organ
change the oil, and then get a load on that thing asap. wring it's neck. don't be afraid.
[Re: OA5599]
#993550
05/16/11 12:36 PM
05/16/11 12:36 PM
Posts: 2,008 Sweet Home Alabama
MRMOPAR622
Sweet Home Alabama
I would hate to give you the wrong advice,but you have already done all that I do before running them. I do not buy into that 500-1,000 mile break-in period.
"To Be The Man'You Have Got To Beat The Man"
"T/D and Pro-Bracket Racer"
[Re: OA5599]
#993553
05/16/11 01:02 PM
05/16/11 01:02 PM
Posts: 3,287 West Coast, USA
jbc426
West Coast, USA
I've always heard to double check all your bolts & lash, be sure about how you have it timed, check carefully for vacuum leaks, spend some time reading plugs to get the jetting right or put a wide band on it, and run it like you are going to use it. Always make sure to have it warmed up before you beat on it.
1970 Plymouth 'Cuda #'s 440-6(block in storage)currently 493" 6 pack, Shaker, 5 speed Passon, 4.10's 1968 Plymouth Barracuda Convertible 408 Magnum EFI with 4 speed automatic overdrive, 3800 stall lock-up converter and 4.30's (closest thing to an automatic 5 speed going)
[Re: jbc426]
#993554
05/16/11 01:37 PM
05/16/11 01:37 PM
Posts: 4,616 Kissimmee Fl.
dusturbd340W5
Kissimmee Fl.
I had maybe 30 minutes run time on mine before I hit the track with it
70 duster full chassis super pro 416 CNC Indybrock heads 727 w/brake
best so far 1.212 60 6.219 in 1/8 at 110.88 9.768 at 137.81 1/4
[Re: dusturbd340W5]
#993555
05/16/11 02:21 PM
05/16/11 02:21 PM
Posts: 3,082 St. Paul , Mn.
tubtar
St. Paul , Mn.
On any street motor I like to seat the rings under acceleration and deceleration. Run it up to 60 - 70 m.p.h. and let her coast down to 40 or so and run it back up with firm , but not flat footed pedal pressure. Repeat this three or four times and then commence to enjoying it. Change oil shortly afterwards and inspect the filter , call it good. I don't buy the 500 mile break in either.
[Re: OA5599]
#993557
05/16/11 02:35 PM
05/16/11 02:35 PM
Posts: 43,317 Bend,OR USA
Cab_Burge
The machine shop and the cylinder wall finish will determine how quick the rings seals ![](/ubbthreads/images/graemlins/thumbs.gif) BTW, SB( 10 head bolts) take longer than BB or Hemi on the dyno to reach peak power, 8 to 15 pulls ![](/ubbthreads/images/graemlins/shruggy.gif) BB and Hemi take 5 to 10 pulls to reach peak power ![](/ubbthreads/images/graemlins/shruggy.gif)
[Re: Streetwize]
#993558
05/16/11 02:40 PM
05/16/11 02:40 PM
Posts: 3,502 SOUTH JERSEY
HEMIFRED
SOUTH JERSEY
if all is done correctly i make one medium pass to make sure nothing falls off the car. Then 6200 and launch ![](/ubbthreads/images/graemlins/apimp.gif)
home of the Sox and Martin Hemi Duster
[Re: HEMIFRED]
#993559
05/16/11 03:59 PM
05/16/11 03:59 PM
Posts: 20,679 in a cattle trailer down by th...
Guitar Jones
I agree, that's me too, five minutes or five feet, which ever comes first. lol
[Re: Voluster]
#993562
05/16/11 10:24 PM
05/16/11 10:24 PM
Posts: 16,932 NC
440Jim
NC
Lots of factors. But ring type (cast, moly, etc), cylinder hone finish, bearing clearance, piston to wall clearance, piston material, ring end gap, etc. etc. etc.
But if built for racing, after 20 minutes to seat the moly rings, it is ready for full power....
That is after checking everything, everything. And changing the oil and filter.
