AVS fast idle screw mounting #993434
05/16/11 08:54 AM
05/16/11 08:54 AM
Indiana
mowch70 Offline OP
mowch70  Offline OP
Indiana
1970 Carter AVS, # 4732, on a 383 automatic. I have attached a picture of the idle screw mounting on this carb. The plastic / phenolic piece fits into a hole in the carb and is where the where the screw is inserted. The end of the screw goes all the way through this piece and adjusts the fast ilde. This piece, over time, has broken into 4 pieces. I've tried super glue, but the large end keeps breaking off. That allows the rest of the piece, with the screw inside it, to push back out the front of the hole. This takes away the fast idle since those pieces slide to the front of the car. I may be able to thread the 5/16's hole that these fit into, but I'd like to fix this right. I took these pieces to a local, 30 year carb shop, and he said he's never seen anything like this. I'm trying to find out if this is stock, aftermarket, or some kind of old school fix. Any help would be appreciated, especially where to locate the plastic piece.
Re: AVS fast idle screw mounting [Re: mowch70] #993435
05/16/11 02:32 PM
05/16/11 02:32 PM
South, FL
cudaized Offline
cudaized  Offline
South, FL
Don't know what you got going there with that set up, but here is a stock look.
Re: AVS fast idle screw mounting [Re: cudaized] #993436
05/16/11 03:25 PM
05/16/11 03:25 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
That's the curb idle screw , fast idle is underneath on the cam coming from the choke butterfly
Re: AVS fast idle screw mounting [Re: JohnRR] #993437
05/16/11 03:59 PM
05/16/11 03:59 PM
Indiana
mowch70 Offline OP
mowch70  Offline OP
Indiana
Then I was mistaken, because that's the screw I am talking about. The red plastic piece fits into the hole from the rear. The problem is that the large ring portion of it, that prevents it from pulling through the hole, broke off. The hole is about 5/16".
I had a carb shop tell me he knows what I'm looking for, but all his cores have a large hole with no plastic piece. Not sure when they did away with this piece and went to making the hole smaller and threading it.
Re: AVS fast idle screw mounting [Re: mowch70] #993438
05/16/11 05:30 PM
05/16/11 05:30 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
You could probably put a keensert in the hole to bring down to the size of that screw.
Re: AVS fast idle screw mounting [Re: JohnRR] #993439
05/16/11 05:52 PM
05/16/11 05:52 PM
Indiana
mowch70 Offline OP
mowch70  Offline OP
Indiana
Thanks for the help.
Re: AVS fast idle screw mounting [Re: mowch70] #993440
05/16/11 09:08 PM
05/16/11 09:08 PM
Is this it?
Re: AVS fast idle screw mounting [Re: RapidRobert] #993441
05/16/11 11:18 PM
05/16/11 11:18 PM
Indiana
mowch70 Offline OP
mowch70  Offline OP
Indiana
Yes, Sir. That's the animal.
Re: AVS fast idle screw mounting [Re: mowch70] #993442
05/16/11 11:21 PM
05/16/11 11:21 PM
Send me your address & it's yours. Let me know if you only need the plastic sleeve w the nub and the flat plastic squarish washer still on the left side of the screw as those non metallic items can go in an envelope. If you need all I can get a mailer they're cheap
Re: AVS fast idle screw mounting [Re: mowch70] #993443
05/16/11 11:33 PM
05/16/11 11:33 PM
NoVa
E
ebodyseast Offline
ebodyseast  Offline
E
NoVa
mowch70 can you post pics of your carb with the grommet installed or a broken piece temporarily installed to show where and how it mounts?
Re: AVS fast idle screw mounting [Re: ebodyseast] #993444
05/16/11 11:56 PM
05/16/11 11:56 PM
Indiana
mowch70 Offline OP
mowch70  Offline OP
Indiana
I won't be able to until this weekend. However, the picture that Cudaized posted shows a good view. The screw in the forefront of the picture adjusts the idle speed. As you screw it in, it increases the idle by pushing on the piece it makes contact with. Sorry, I don't know the technical name of what that piece is called. On my carb, the red plastic "sleeve" fits into the hole the screw goes into. It looks like on the picture posted that the hole is threaded. On mine, the hole is a lot bigger than the screw, and the sleeve fits into the hole, and the screw goes into the threaded center of the sleeve. The sleeve is pushed into the hole from the rear, allowing the larger part, or shoulder of the sleeve, to fit against the back of the carb casting. This prevents the sleeve from pulling out the front of the hole. The shoulder broke off of mine and the rest of the sleeve, with the screw still inside, slid out of the hole, since there's pressure on it from behind. If you need pics, I'll post them this weekend.
Re: AVS fast idle screw mounting [Re: mowch70] #993445
05/17/11 01:26 AM
05/17/11 01:26 AM
NoVa
E
ebodyseast Offline
ebodyseast  Offline
E
NoVa
That's the ground terminal, so don't worry about pics, thanks anyways - good to see/know there are some good folks on here still...
