hvlp turbine spray painting #993059
05/15/11 05:19 PM
05/15/11 05:19 PM
florida
74fldart Offline OP
74fldart  Offline OP
florida
has anyone here used the turbine hvlp systems? im thinking about getting one but wanted some feedback on them if possible.
Re: hvlp turbine spray painting [Re: 74fldart] #993060
05/15/11 08:04 PM
05/15/11 08:04 PM
Bellevue,Mich.
Dodge33 Offline
Dodge33  Offline
Bellevue,Mich.
I have used one from tp tools, it takes some getting use to.
the air is heated so you have to play with your reducer's.use slower one's to take up for the warm turbine air. but I think you will be happy.
Re: hvlp turbine spray painting [Re: Dodge33] #993061
05/15/11 09:22 PM
05/15/11 09:22 PM
Columbus, Ohio
Chally426 Offline
Chally426  Offline
Columbus, Ohio
I've got one and love it, The new guns run on 10 psi or less. very little over spray, as said above use a slower reducer and over reduce the material by 10% or so and your be happy
Re: hvlp turbine spray painting [Re: Chally426] #993062
05/15/11 11:44 PM
05/15/11 11:44 PM
Phila Pa
scatpacktom Offline
scatpacktom  Offline
Phila Pa
I have a accu-spray unit I bought years ago from Eastwood. I painted my red 71 Super Bee in my filthy shop with it. I really like it.
Re: hvlp turbine spray painting [Re: Chally426] #993063
05/16/11 12:03 AM
05/16/11 12:03 AM
fredericksburg,va
cudaman1969 Offline
cudaman1969  Offline
fredericksburg,va
i have used one for 23 years (same one, Chroix). use it in my cabinet business. i have sprayed everything from thin water born to thick latex just adjusting the air and cap nozzle. the most important piece would be the adjustable air shut off before it goes in the gun(like a regulator). i painted my 70 cuda race car (95 stealth pearl yellow)in one hour,base coat pearl coat and clear coat. only used 1 1/2 quarts base, one quart pearl, and little under 3 quarts clear. did it in my garage with no over spray at all, nothing on the walls or floor. dry in two hours top. it came out smooth as silk. why anyone would use a regular gun i don't know.
Re: hvlp turbine spray painting [Re: cudaman1969] #993064
05/16/11 10:59 PM
05/16/11 10:59 PM
Ontario, Canada
Stanton Offline
Don't question me!
Stanton  Offline
Don't question me!
Ontario, Canada
I've heard complaints of severe orange peel but that may be due to the wrong reducers when using that type of unit. I used a friends to do a few things and was extremely happy with the results and I'm no pro by any means. I especially like the lack of overspray and fumes !! Not having to worry about moisture or contaminants in the lines is definately a bonus. The big hose attached to the gun is probably the only downside. It'd be really cool if they made small (touch-up) guns for those units.
Re: hvlp turbine spray painting [Re: Stanton] #993065
05/18/11 09:30 PM
05/18/11 09:30 PM
Columbus, Ohio
Chally426 Offline
Chally426  Offline
Columbus, Ohio
They do make a small touch up gun for these units...
