Re: BIG BLOCK IN A DUSTER
[Re: runner12]
#992900
05/15/11 04:18 PM
05/15/11 04:18 PM
Posts: 964 Nanaimo, B.C.
GwaiiEagle
Mannix
Mannix
Nanaimo, B.C.
Is this a RB Block?
Are you trying to install the motor with the headers attached?
[Re: runner12]
#992902
05/15/11 05:06 PM
05/15/11 05:06 PM
Posts: 5,221 Branson, Mo.
joedust451
super gas
super gas
Branson, Mo.
Building big block duster with 73 spool mount k fram schumacher mounts indy ez heads and tti headers. The pass side header is hitting the inner fender and still needs to drop ahalf inch in the mount, anyone have any go rounds with a simular set up?????? thanks
They can be tricky those spool mounts, like mentioned, install the bolts but leave them loose, it'll make it easier to monipulate the mounts in the sockets, sometimes they are tight & you need to give them alittle help.
The header should not be hitting the inner fender even if its still 1/2" up on the mount i wouldn't think, Was this the shuamacker kit & useing a 6cyl. k-member? If so, did you follow the instructions & drill the holes on the DS along with cutting the DS corner on the k-member to clear the oil pump.
[Re: runner12]
#992906
05/16/11 02:52 AM
05/16/11 02:52 AM
joedust451
super gas
super gas
Branson, Mo.
this is a 440 block and the mounts were purchased used ... no instructions. as far as the k member not sure if its 6 cyl or small block.
You need to go back to the drawing board & find out what your working with for the K-member, you most likely have the wrong mounts too.
