Seen that happen a few times before.flush the trans with completly new fluid.(use a machine)or homemade,get 2 buckets,fill 1 with new fluid put a trans line in the bucket,put the other line in the empty bucket,the trans should suck in the new fluid and push the old crap out.Might do this a second time after a couple hundred miles to be sure.1 car it did take out the trans,but it didn't show up for about 6 months.luckily still under warranty. make sure you use the right fluid.atf+4 little pricey,but you will have problems if you don't..
