Body Control Module question, 98 T&C van #992210
05/14/11 01:58 PM
05/14/11 01:58 PM
Missouri
galen Offline OP
galen  Offline OP
Missouri
P04801062AC body control module. Mine is shorted, I have the one with alarm system. Can I use the same # module without alarm system. They have both on ebay but I would just as soon do away with the alarm if possible. If I buy the one with the alarm I am not sure whether I can program it to my key fob. Galen
Re: Body Control Module question, 98 T&C van [Re: galen] #992211
05/14/11 06:10 PM
05/14/11 06:10 PM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
Not if it is factory alarm. Theh body controller along with the PCM are set to have the alarm. The PCM will look for a signal over the bus from the BCM to say its ok to start. If you put a BCM in without alarm the car wont start. Ron
