need help with a 8.25 rear #992015
05/14/11 01:47 AM
05/14/11 01:47 AM
georgia
1340busa Offline OP
1340busa  Offline OP
georgia
i have a 74 roadrunner with a 8.25 rear. i bought a nos posi unit for it. i also bought 3.55 gears out of a 96 jeep. the problem is that when i install the carrier in the housing with the ring gear on it the pinion gear will not mesh correctly. am i supposed to use a pinion bearing from a 96 jeep? i have new bearings on the carrier for a 74 roadrunner.
Re: need help with a 8.25 rear [Re: 1340busa] #992016
05/14/11 04:30 AM
05/14/11 04:30 AM
Granite Bay CA
Kern Dog Offline
Striving for excellence
Kern Dog  Offline
Granite Bay CA
This really isn't a job for a first timer. The ring and pinion gears are a matched set, and setting them up requires a few specialized tools. If you tried to keep the original pinion gear in the housing, its a bad idea. If its a different ratio, theres no way it will work. The tooth count on each ratio is different and they will not mesh. Also, POSI is a Chevrolet term. Mopars used the name Sure Grip.
Re: need help with a 8.25 rear [Re: 1340busa] #992017
05/14/11 05:13 AM
05/14/11 05:13 AM
md
W
wicked Offline
wicked  Offline
W
md
Isn't the jeep rear a Dana? never work
Re: need help with a 8.25 rear [Re: wicked] #992018
05/14/11 06:10 AM
05/14/11 06:10 AM
San Jose,CA
migsBIG Offline
YouTube is my go-to news source
migsBIG  Offline
San Jose,CA
I think after 1998 the 8.25 rear was designed so earlier parts may not interchange. Not sure 100%, but I do remeber somebody on here posting a similar thing that happened.
Re: need help with a 8.25 rear [Re: migsBIG] #992019
05/14/11 09:15 AM
05/14/11 09:15 AM
Southern Oregon
toyotajeep Offline
toyotajeep  Offline
Southern Oregon
Spline count in the sure-grip is different on the newer stuff. I don't know that there is much difference in the gears alone.
I will say however, that setting up a ring and pinion properly is a job. I'd look into the local 4x4 shop. They do it all the time. I know a guy who does several vehicles a week front and rear.
It is possible to do yourself, but it is pretty crucial that you get things right.
ROB
1989 Dodge Cummins & 1989 Dodge W-250
Re: need help with a 8.25 rear [Re: 1340busa] #992020
05/14/11 10:25 AM
05/14/11 10:25 AM
Conway, SC
T2R9 Offline
T2R9  Offline
Conway, SC
Was the sure grip unit for a 2.45 gear set? If so this is the problem. There are lots of these out there for sale right now. If you install the ring gear on your original open carrier will it set up?
The 96 ring and pinion should not be an issue. I installed a 3.55 from a Jeep in my Duster with no problem at all. The spline count did change on the carrier on later ones but the gears were not affected.
Re: need help with a 8.25 rear [Re: T2R9] #992021
05/14/11 11:30 AM
05/14/11 11:30 AM
georgia
1340busa Offline OP
1340busa  Offline OP
georgia
i am not doing this myself. the car is at a shop. the car had 3.21 orginally and the carrier i bought is for these or 3.55's. i remember reading somewhere that the bearings changed during the production run.
Re: need help with a 8.25 rear [Re: 1340busa] #992022
05/14/11 11:36 AM
05/14/11 11:36 AM
Southern Oregon
toyotajeep Offline
toyotajeep  Offline
Southern Oregon
Now that you mention it, I think you're right on that account to.
