Plug gap autolites #991974
05/14/11 12:16 AM
05/14/11 12:16 AM
Eldridge, IA
HR5058 Offline OP
HR5058  Offline OP
Eldridge, IA
Got my Autolite plugs. One set of 3910 and one set of 3911. Autolite tech guy said that they are pre gapped at 25 and to leave it there. Seems awful tight. What do you all think?
418 CU SB
Aluminum heads
12.7-1 compression
112 race fuel
Chuck
Re: Plug gap autolites [Re: HR5058] #991975
05/14/11 12:35 AM
05/14/11 12:35 AM
Rock Springs
Bob_Coomer Offline
Bob_Coomer  Offline
Rock Springs
between .030-.040 is close enough for me..
Re: Plug gap autolites [Re: HR5058] #991976
05/14/11 01:13 AM
05/14/11 01:13 AM
Got my Autolite plugs. One set of 3910 and one set of 3911.  Autolite tech guy said that they are pre gapped at 25 and to leave it there.  Seems awful tight.  What do you all think?418 CU SBAluminum heads12.7-1 compression112 race fuelThanksChuck
All of the 3911 and 3910 I have bought and used had .035 from the factory, I gap mine at .045 for pump gas and using a MSD 7 ignition with the proper coil for the race boxes
Re: Plug gap autolites [Re: Cab_Burge] #991977
05/14/11 02:21 AM
05/14/11 02:21 AM
Arizona
Chris'sBarracuda Offline
Arizona
Whatever Autolite says is probably the correct answer. I'm quite sure they have much much more test equipment and dyno time than all of us put together.
A really smart Pro Stock engine builder told me that some time ago.
I think my NGK's are .028 out of the box. R5671's..
Chris..
