Re: Adjustable voltage regulator?
[Re: plysat]
#991819
05/13/11 10:33 PM
05/13/11 10:33 PM
Posts: 21,072 Niles , Ohio
therocks
Niles , Ohio
I dont know about that.But just get the new style that is plug and play for OE.Its electronic and unless you have electrical problems they work great.Had them installed on 4 early cars and no problems.rocky
Chrysler Firepower
[Re: plysat]
#991820
05/14/11 12:11 AM
05/14/11 12:11 AM
RapidRobert
I remem seeing a pic of one of those decades ago. if it functioned I'd like to have/try one to play w ch voltage a bit & I've thought about using a variable resistor of some sort just to do some experimenting but I dont have enough electronic savvy to pull it off. You have one? I was thinking it had a little screwdriver slot flush w the case
[Re: earlybee]
#991822
05/14/11 12:37 AM
05/14/11 12:37 AM
RapidRobert
that's it. What Therocks said, the stock electronic works pretty good. IF all terminals/connections have minimal resistance & I like a better alt/relays on the heavy draws. On the older setup an electronic version is highly recommended
