Alignment/front end suspension questions
#991151
05/12/11 06:51 PM
05/12/11 06:51 PM
Posts: 1,345 Rohnert Park, Ca
ryan053
Rohnert Park, Ca
So I am in the process of replacing some the front end suspension on my 68 Charger. I use the car strictly for driving around town and on occasional a pass at the 1/4 mile. I just replaced the upper control arm bushing, the upper and lower ball joints, the idler arm, the sway bar stabilizers and bushings. The part numbers i used are k408, k6629, k781, k783, k772. After I replaced all of the parts and took the car to the shop to have it aligned the front tires have been squealing like crazy. I took it back in today and had them redo the alignment but the tires are steal squealing. They don't seem to squeal as much but its still noticeable. The shop thinks there is a problem with the toe adjustment. They currently have the toe set at zero. They have been able to adjust the camber properly but they haven't been able to adjust the caster to normal specs. Currently the pass side has -5.6 degrees caster and the driver side has -0.2 degrees. The camber is set at 0.1 degrees on both tires. While I was under the car looking around I noticed the driver side torsion bar nut isn't even with the pass side torsion bar nut. It looks as though the nut was tightened a lot more on the pass side. On the drivers side the washer behind the nut is loose. I can freely move it around. The height of the car on the driver side is about an inch more than the pass side. If I understand the factory manual correctly if I tighten that nut on the driver side torsion bar it will raise that side of the car even more.
So my questions are: What would cause the tires to squeal while driving? Does it sound like the torsion bar is adjusted correctly?
Re: Alignment/front end suspension questions
[Re: ryan053]
#991156
05/12/11 11:25 PM
05/12/11 11:25 PM
Posts: 643 southern conn
1969gtx
southern conn
if the nut that hold the lower control arm are loose the alignment spc. will not stay in spc. but if the ride hieght was not ajusted that the frist thing to set before doing and alignment. an look close at the k frame at the point the control arm fit. I have see the weld around the sleve break an yes I hav reweld them
1965 A/FX Plymouth 9.50 et @139 mph 1965 A/FX awb plymouth flashback [email]10.26@129mph[/email] mph on pump gas 426 hemi 1969 GTX Hemi 4 speed 12.50 et @ 112mph in F.A.S.T TRIM 1970 GTX 4406pac 4 speed 11.05 @126.9 mph in F.A.S.T TRIM http://www.AFXER.com
[Re: ryan053]
#991157
05/13/11 09:27 AM
05/13/11 09:27 AM
Posts: 21,073 Niles , Ohio
therocks
Niles , Ohio
If you have neg 5 degrees caster that car will never drive right.Id adjust the T bars and as said check the lower bushings.Sounds like you need Moog off set upper bushings.My 65 had a lot of neg caster.I pulled the polys and went Moog offsets.Now Im at about .5 neg caster and my camber is at about 0.Been a few years since I did the alingment.I did it myself that why I know its right.You cant use the factory spec unless you are running Bias tires.Rocky
Chrysler Firepower
[Re: Sport440]
#991159
05/13/11 10:58 PM
05/13/11 10:58 PM
therocks
Niles , Ohio
Im looking at the pics and thought I didnt see a T bar or the T bar bolt.My eyes are bad an I thought I was missing something.Age really sometimes wont make a differenc in the bushings.My 65 when I pulled them to install new were just like new after 40 years.I almost didnt change them.I agree sounds like the lowers are bad and maybe some frame cracking.Rocky
Chrysler Firepower
