Re: edelbrock head decking question
[Re: dcr]
#991087
05/12/11 11:20 PM
05/12/11 11:20 PM
Posts: 6,591 Canton, Ohio
Sport440
Canton, Ohio
Like Wild Bill stated, the Eddy head is plenty thick, .625 to be exact. Hows that compare? MP boasted about the old Stage 6 head being .450 thick, with a max recommended .100 cut reducing that to .350.
If you cut your head that far, you will still have a thicker deck .525 thick then a uncut MP stage 6 head @ .450. But you will need to address the intake issues and the extra reduced P/V clearence that will occur.
If you shave the heads intake surface the the respective ratio of .0123 off the intake for every .010 off the flat. The heads intake surface will be recessed pretty deep from the Vally pans rail causing a gap problem. You will need to address that some way.
Cut the rails, stack paper gaskets, take less off the intake side of then recommended, cut the intake itself. etc, etc.
