Small block questions....
#991053
05/12/11 05:34 PM
05/12/11 05:34 PM
Posts: 6,531 Jacksonville, FL
Chris2581
Jacksonville, FL
Drag racing engine up to 7200 rpm...3.31 stroke.. only needs to run 10.50's in a 3400lb A-body.
1. What is a good wet sump oiling system combo??
2.Heads..are the Magnum R/T heads good and are they around?? If not what's the best stock head to use?? Heads will be ported.
3.Intake...whats good?? Have to use a spread bore type carb(TQ or Rochester)
4.Rods and crank...who has the good stuff??
Cam..solid or roller?? Prefer a solid due to costs,but if roller will be better in long run,I'd go that route.
Re: Small block questions....
[Re: Chris2581]
#991054
05/12/11 05:56 PM
05/12/11 05:56 PM
Posts: 12,008 Finally a HUSKER again
Moparnut426
PM one of the builders on here close to you.
I personally recomend Dan at performance only, but there is many builders on here that do good work and have the numbers to prove it.
Asking that generic of a question on this board is gonna get ya confused by replies.
Personally id go,
Ported "308" or J heads,
Hughes solid flat tappet cam,
K1 rods and crank, or stock 340/318 steel crank,
Diamond, or comparable forged pistons,
and have your builder spec the cam, compression, carb,
as for oiling, just a good ol high volume oil pump.
Kasey
[Re: Quicktree]
#991056
05/12/11 06:30 PM
05/12/11 06:30 PM
Chris2581
Jacksonville, FL
No W2's.... has to be a stock type head..10.70 to 10.80 is a more realistic ET though. Tony,I sent you a PM,but don't spill the beans.
[Re: emarine01]
#991058
05/12/11 06:47 PM
05/12/11 06:47 PM
Quicktree
Where is Vic at
thats who he needs, but vic spins the gebus out of his
[Re: S/ST 3040]
#991060
05/12/11 06:50 PM
05/12/11 06:50 PM
Quicktree
3400 lbs. and 7200 RPM??
Me no can do.
thats what I thought. going to be tuff to climb that mountain
[Re: Chris2581]
#991062
05/12/11 06:57 PM
05/12/11 06:57 PM
Posts: 614 Michigan
Get-X
GenIII hemi all the way. It's a production head and has way more potential then other OE heads.
'65 Belvedere '68 GTX '57 Dodge pickup
[Re: Get-X]
#991064
05/12/11 07:08 PM
05/12/11 07:08 PM
Posts: 3,395 Pa
Hot 340
Pa
lol.
[Re: S/ST 3040]
#991067
05/12/11 07:26 PM
05/12/11 07:26 PM
Chris2581
Jacksonville, FL
I threw out 7200 as a base line..can go higher I guess..I'm a big block guy....don't need to run those 383 and 440's that high.Last time I raced a small block was 30 years ago,so I know what I ran then is outdated.
10.70-10.80 ET is what I'm after.Doesn't need to go faster than 10.70.
[Re: S/ST 3040]
#991068
05/12/11 07:26 PM
05/12/11 07:26 PM
Quicktree
Actually, I could do it and it gets done every weekend in Super Stock.
........just not at 7200 RPM.
yea I don't see any stock based motor doing it at 7200.Chris I do have a virgin X headed 340 i'll make you a deal on if you need it.
[Re: Chris2581]
#991069
05/12/11 07:28 PM
05/12/11 07:28 PM
Quicktree
you will need to spin it 8k plus I bet
[Re: emarine01]
#991071
05/12/11 07:59 PM
05/12/11 07:59 PM
Chris2581
Jacksonville, FL
Yes..3.31 stroke. I know a 3.58 or 4.00 stroke is a easier engine to build to run 10.70's.
[Re: Chris2581]
#991072
05/12/11 09:19 PM
05/12/11 09:19 PM
Posts: 52,972 Romeo MI
MR_P_BODY
I think it would be much easier if you layed out the rules or restrictions... if you have to stay at the stock stroke you better turn UP the revs... 7200 is barely past the stock revs
