'08 Charger Radio #991034
05/12/11 04:50 PM
05/12/11 04:50 PM
N. Ca.
floorit426 Offline OP
N. Ca.
Hi,
The radio stopped working in my '08 Charger. It is totally dead, with no sign of power. I checked the 20 amp fuse in the rear fuse box and it is fine. Just the radio stopped working, nothing else. Does anyone have an idea of what the problem could be?
Re: '08 Charger Radio [Re: floorit426] #991035
05/12/11 05:53 PM
05/12/11 05:53 PM
Pataskala, Ohio
GTX70sixpack Offline
Pataskala, Ohio
The radios are junk. I have had 2 in a van, 3 in my Dakota, 3 in moms stratus. I usually buy dealer take outs for 100-125 bucks but I have a hook up at a dealer
65 Belvedere II Station Wagon
69 Coronet R/T convertible
70 GTX
70'cuda
99 Dodge Diesel dually 4X4
Re: '08 Charger Radio [Re: GTX70sixpack] #991036
05/12/11 08:10 PM
05/12/11 08:10 PM
wisconsin
mod381 Offline
mod381  Offline
wisconsin
Try unhooking battery and letting it sit for a few minutes. It has worked on a few,and it does not cost anything.
Re: '08 Charger Radio [Re: floorit426] #991037
05/12/11 08:24 PM
05/12/11 08:24 PM
Ohio
Todd Offline
Todd  Offline
Ohio
Did you check the IOD fuse?
Re: '08 Charger Radio [Re: Todd] #991038
05/13/11 10:28 AM
05/13/11 10:28 AM
N. Ca.
N. Ca.
No. I'll bite, what's an IOD fuse?
Re: '08 Charger Radio [Re: floorit426] #991039
05/13/11 10:35 AM
05/13/11 10:35 AM
It's a dry heat
gtx6970 Offline
gtx6970  Offline
It's a dry heat
Ignition off draw fuse.
used to retain memory in various electrical components
Re: '08 Charger Radio [Re: floorit426] #991040
05/13/11 10:44 AM
05/13/11 10:44 AM
Ohio
Todd Offline
Todd  Offline
Ohio
IOD stands for Ignition off draw. Its in the PDC in the trunk. It has a black or white housing and is a 60 amp fuse inside of the cartrage. Look on the lid of the PDC if your unsure where it is. When the cars are shipped new this fuse is in the up position to keep the battery from going dead. Alot of times just removing this fuse and reinstalling will correct your concern due to the fuse not properly seated all the way.
Front Power Distribution Center Fuses
A power distribution center is located in the engine compartment. This center contains fuses and relays.
CAUTION: When installing the Power Distribution Center cover, it is important to ensure the cover is properly positioned and fully latched. Failure to do so may allow water to get into the Power Distribution Center, and possibly result in an electrical system failure.
When replacing a blown fuse, it is important to use only a fuse having the correct amperage rating. The use of a fuse with a rating other than indicated may result in a dangerous electrical system overload. If a properly rated fuse continues to blow, it indicates a problem in the circuit that must be corrected.
Cavity Cartridge Fuse Mini-Fuse Description
1 — 15 Amp Blue Washer Motor
2 — 25 Amp Neutral Powertrain Control Module (PCM)
3 — 25 Amp Neutral Ignition Run / Start
4 — 25 Amp Neutral Alternator / EGR Solenoid
5 — 15 Amp Blue Engine Control Module (Diesel)
6 — 25 Amp Neutral Ignition Coils/Injectors / Short Runner Valve
7 — 25 Amp Neutral Interior Lamps / Under Hood Lamps (Police)
8 — 25 Amp Neutral Starter
9 — — Starter Relay
10 30 Amp Pink — Windshield Wiper
11 30 Amp Pink — Anti-Lock Brake System (ABS) Valves - If Equipped
12 40 Amp Green — Radiator Fan
13 50 Amp Red — Anti-Lock Brake System (ABS) Pump Motor - If Equipped
14 — — —
15 50 Amp Red — Radiator Fan
16 — — Wiper On / Off Relay
17 — — Wiper High / Low Relay
18 — — Radiator Fan Control Relay
19 — — Radiator Fan High / Low Control Relay
20 — — Radiator Fan High Relay
21 — — Auto Shut Down Relay
22 — — Run / Start Relay
Rear Power Distribution Center Fuses
There is also a power distribution center located in the trunk under the spare tire access panel. This center contains fuses and relays.
Cavity 1 of the Rear Power Distribution Center contains a black IOD fuse needed for vehicle processing during assembly. The service replacement part is a 60 Amp yellow cartridge fuse.
Cavity Cartridge Fuse Mini Fuse Description
1 60 Amp Yellow — Ignition Off Draw (IOD)
2 40 Amp Green — Battery
3 — 20 Amp Yellow Lamp Dome (Police)
4 40 Amp Green — Battery
5 30 Amp Pink — Heated Seats - If Equipped
6 — 20 Amp Yellow Fuel Pump
7 — 15 Amp Blue Lamp Spot Right (Police)
8 — 15 Amp Blue Ignition Switch / Airbag Control Module (ACM)
9 — 20 Amp Yellow Console Power Outlet
10 — — —
11* — — Circuit Breaker 1
12* — — Circuit Breaker 2
13* — — Circuit Breaker 3
14 — 10 Amp Red AC Heater Control / Cluster/ Sentry Key Remote Keyless Entry
15 — 20 Amp Yellow Trailer Tow Brake Module - If Equipped
16 — 20 Amp Yellow Power Outlet Rear
17 — 20 Amp Yellow Cluster
18 — 20 Amp Yellow Selectable Power Outlet
19 — 10 Amp Red Stop Lights
20 — 20 Amp Yellow Rear Wiper Relay
21 — — Run Relay
22 — — Rear Window Defogger Relay
23 — — Accessory Delay Relay
24 — — Transmission Relay (NAG1)
25 — — —
26 — — Rear Wiper Relay
27 — 10 Amp Red Airbag / Airbag Control Module (ACM)
28 — 10 Amp Red Curtain Airbag - If Equipped
29 — 5 Amp Orange Anti-lock Brakes Module - If Equipped / Cluster / Front Control Module (FCM) / Powertrain Control Module (PCM) / Sentry Key Remote Keyless Entry / Stop Lights
30 — 10 Amp Red Door Modules / Power Mirrors - If Equipped/Steering Control Module
31 — — Diode 2
32 — — Diode 1 (NAG1)
33 — — Diode - Zener
34 — — Spare
35 — 5 Amp Orange Amplifier - If Equipped / Antenna / Ignition Delay / Overhead Console / Passenger Door Lock And Express Power Window Switch - If Equipped / Power Mirrors - If Equipped / Rain Sensor - If Equipped / Rear Defrost
36 — 20 Amp Yellow Hands Free Phone - If Equipped / Media System Monitor DVD - If Equipped/Radio/Satellite Receiver - If Equipped
37 — 15 Amp Blue Transmission - NAG1
38 — 5 Amp Orange Analog Clock/Cargo Light/Overhead Console
39 — 10 Amp Red Heated Mirrors - If Equipped
40 — 5 Amp Orange Heated Seats - If Equipped/Inside Rearview Mirror
41 — 10 Amp Red AC Heater Control/Park Assist - If Equipped/Tire Pressure Monitoring - If Equipped
42 30 Amp Pink — Front Blower Motor
43 30 Amp Pink — Amplifier - If Equipped/Antenna/Rear Defrost
44 20 Amp Blue — Amplifier - If Equipped/Front Control Module (FCM)/Sunroof - If Equipped
45 — — Lamp Activation Relay
46 — — Fuel Pump Relay
47 — — Rear Heated Seats Relay
*Cavities 11, 12, and 13 contain self-resetting fuses (circuit breakers) that are only serviceable by an authorized dealer. The Cluster (without power memory seat), the Driver Seat Switch (with power memory seat), and the Memory Module (if equipped) are fused by the 25 amp circuit breaker in Cavity 11. The Passenger Seat Switch is fused by the 25 amp circuit breaker in Cavity 12. The Door Modules (except base), the Driver Door Lock Switch (base), the Driver Express Power Window Switch (if equipped), and the Passenger Door Lock Switch (base) are fused by the 25 amp circuit breaker in Cavity 13. If you experience temporary or permanent loss of these systems, see your authorized dealer for service.
Re: '08 Charger Radio [Re: Todd] #991041
05/13/11 11:05 AM
05/13/11 11:05 AM
N. Ca.
N. Ca.
Wow, you guys are awesome, great info! Thanks, I'm sure I'll be cruising down the road with the Skynnard cranked up in no time!
Thanks, again.
