TM-7 Intake.! Have you ever run one before.? #991014
05/12/11 04:46 PM
05/12/11 04:46 PM
Maryville tn
67coronetman Offline OP
Maryville tn
So has anyone ever used a edelbrock TM-7 Intake if so how did it run for you and what would you say about it street manners.? scale from 1-10 my motor if built fairly well but not a street beast.
Old car are me......
Re: TM-7 Intake.! Have you ever run one before.? [Re: 67coronetman] #991015
05/12/11 04:57 PM
05/12/11 04:57 PM
Jacksonville, FL
Chris2581 Offline
Chris2581  Offline
Jacksonville, FL
Real good intake. What is your combo?
Nautilus Racing-
Re: TM-7 Intake.! Have you ever run one before.? [Re: Chris2581] #991016
05/12/11 06:08 PM
05/12/11 06:08 PM
Maryville tn
Maryville tn
440 bored .040 over indy heads mild port work large TTI headers 2" to 2 1/8 step headers solid lift comp cam almost 600 on the ext side.
Re: TM-7 Intake.! Have you ever run one before.? [Re: 67coronetman] #991017
05/12/11 07:35 PM
05/12/11 07:35 PM
Tustin, CA
P
pishta Offline
pishta  Offline
P
Tustin, CA
Check out Mopar Actions Intake shootout. TM-7 fared pretty well. Just buy one that's matched to your build and you'll be set.
12 Grand Caravan
06 T&C
02 T&C
96 Breeze
65 Barracuda "S"
Re: TM-7 Intake.! Have you ever run one before.? [Re: 67coronetman] #991018
05/13/11 01:08 AM
05/13/11 01:08 AM
PORT ALBERNI , BC., CANADA
superwrench Offline
superwrench  Offline
Used one on the old 440 in the Challenger......great intake . Loves 800+ cfm carbs.
Re: TM-7 Intake.! Have you ever run one before.? [Re: superwrench] #991019
05/13/11 10:07 AM
05/13/11 10:07 AM
Maryville tn
Maryville tn
I am going to give it a try i have a 950 carb and will the cam heads and headers and so on i think i will have a good combo.!
Re: TM-7 Intake.! Have you ever run one before.? [Re: 67coronetman] #991020
05/13/11 10:42 AM
05/13/11 10:42 AM
Moved to N.E. Tennessee
GomangoCuda Online work
GomangoCuda  Online Work
Yep, performance will be very close to the Victor intake and it will fit without a hood scoop.
Re: TM-7 Intake.! Have you ever run one before.? [Re: 67coronetman] #991021
05/13/11 12:55 PM
05/13/11 12:55 PM
Sk. Canada
RemCharger Offline
RemCharger  Offline
Sk. Canada
What kind of indy heads.... ?
Re: TM-7 Intake.! Have you ever run one before.? [Re: RemCharger] #991022
05/13/11 01:19 PM
05/13/11 01:19 PM
Maryville tn
Maryville tn
Indy Sr have mild port work done to them.! They flowed 335.5 @ 700 lift
Re: TM-7 Intake.! Have you ever run one before.? [Re: 67coronetman] #991023
05/13/11 01:23 PM
05/13/11 01:23 PM
Sk. Canada
RemCharger Offline
RemCharger  Offline
Sk. Canada
I think you will be leaving some hp on the table, but it will work fine for rolling around.
Re: TM-7 Intake.! Have you ever run one before.? [Re: RemCharger] #991024
05/13/11 02:35 PM
05/13/11 02:35 PM
Maryville tn
Maryville tn
Well i wanted a M-1 intake but i found this one and i have heard good things about it so that is why and its a good price for now plus i will have it port matched to my heads. I can"t imagine i am loseing to much i had a edelbrock performer RPM on it before.
Re: TM-7 Intake.! Have you ever run one before.? [Re: 67coronetman] #991025
05/13/11 11:35 PM
05/13/11 11:35 PM
Columbia Station, Ohio
69RTSE Offline
69RTSE  Offline
Thats the intake I have on my '69 Charger. 440/auto, .040" over, 10to1 comp, iron heads with big valves, Comp Cams hydraulic .507"/.510" cam, TTI 1-7/8" headers and 3" exhaust, and a BG 750 carb. All steel car, probably about 38-3900lb race weight. Went 12.20s with slicks and 4.10s. Also went 12.80s with 3.23s and regular street tires. Good intake, no problems on the street.
Re: TM-7 Intake.! Have you ever run one before.? [Re: 69RTSE] #991026
05/14/11 12:04 PM
05/14/11 12:04 PM
Maryville tn
Maryville tn
Thanks for the reply did you do any port work on the heads or bigger valves or intake porting at all.?
Re: TM-7 Intake.! Have you ever run one before.? [Re: 69RTSE] #991027
05/16/11 08:45 AM
05/16/11 08:45 AM
Maryville tn
Maryville tn
I am hoping with my set up it will really wake the motor up more than with the edelbrock performer RPM intake. I keep hearing other say a single plane is no good for street use but 90% of my friends run them all the time and have been on me for some time to change and see the diff it makes so i am time will tell.!
Re: TM-7 Intake.! Have you ever run one before.? [Re: 67coronetman] #991028
05/16/11 11:53 AM
05/16/11 11:53 AM
Ontario, Canada
Dodgem Offline
Dodgem  Offline
Ontario, Canada
what are you trying to do Be specific.
1. you may want to look at indy's dual plane intake for standard intake port (you did not say max wedge)
2. or step up to a victor junior standard port what is street able is real suggestive
TM7 is a good intake don't think there will be a big overall difference from a RPM performer?? less down low more up top kind of thing.
The Indy dual plane is supposed to be the best dual plane out there.
Re: TM-7 Intake.! Have you ever run one before.? [Re: 67coronetman] #991029
05/16/11 11:58 AM
05/16/11 11:58 AM
Ontario, Canada
Dodgem Offline
Dodgem  Offline
Ontario, Canada
I'm old as dirt and never ran anything but a single plane on the street.
better options now the RPM and Holley SD give the best of both worlds.
The big Indy dual plane is better yet I'm told then just move right up to victor.
You still have both feet don't you??
Re: TM-7 Intake.! Have you ever run one before.? [Re: Dodgem] #991030
05/16/11 02:37 PM
05/16/11 02:37 PM
Maryville tn
Maryville tn
Oh well some like them and some don't just like anything we all have or opinions of what works best so i guess i will do what i want and if it works good great & if it don't i will pay the price.!
Re: TM-7 Intake.! Have you ever run one before.? [Re: 67coronetman] #991031
05/16/11 03:42 PM
05/16/11 03:42 PM
Ontario,Canada
firefighter3931 Offline
Ontario,Canada
The TM7 is an excellent manifold. When we dynoed my old 446 there were 4 intake manifolds tested ; TM7/Victor/Street Dominator/Performer Rpm
The TM7 vs SD was almost identical...within 1-2 TQ/HP of each other (535hp/540tq) The Victor made 10 more hp but also pushed the peaks up higher. The RPM was down about 25hp but it did make more tq below 3000 than any of the single planes.
My engine combo is very similar to yours although you have better heads than i do....My RPM's flowed right at 300cfm @ .600 valve lift.
I ended up using the Street Dominator with an 850 DP using a 4200 stall & 4.10's the car ran a best of 11.68@116 with a raceweight of 4100 lbs.
Assuming you have enough stall and gear the TM7 will show some nice top end improvement. I would recommend a 1in open spacer for increased plenum volume....mine liked it !
Ron
Re: TM-7 Intake.! Have you ever run one before.? [Re: firefighter3931] #991032
05/16/11 05:29 PM
05/16/11 05:29 PM
Maryville tn
Maryville tn
Thanks so much for the reply and info. It seem other take it in a bad was when i make a comment but i do thank you for the info again.!
Have a great day.
Re: TM-7 Intake.! Have you ever run one before.? [Re: 67coronetman] #991033
05/16/11 07:25 PM
05/16/11 07:25 PM
Ontario, Canada
Dodgem Offline
Dodgem  Offline
Ontario, Canada
Hope you don't mean me all the intakes have merits. just meant if you are super performance orientated like I usually am the victor even if you had to tickle the throttle at idle in gear is not a bad thing to me at least!
