Re: TM-7 Intake.! Have you ever run one before.?
[Re: Chris2581]
#991016
05/12/11 06:08 PM
05/12/11 06:08 PM
Posts: 768 Maryville tn
67coronetman
Maryville tn
440 bored .040 over indy heads mild port work large TTI headers 2" to 2 1/8 step headers solid lift comp cam almost 600 on the ext side.
Old car are me......
[Re: 67coronetman]
#991017
05/12/11 07:35 PM
05/12/11 07:35 PM
Posts: 893 Tustin, CA
pishta
Tustin, CA
Check out Mopar Actions Intake shootout. TM-7 fared pretty well. Just buy one that's matched to your build and you'll be set.
12 Grand Caravan 06 T&C 02 T&C 96 Breeze 65 Barracuda "S"
[Re: superwrench]
#991019
05/13/11 10:07 AM
05/13/11 10:07 AM
67coronetman
Maryville tn
I am going to give it a try i have a 950 carb and will the cam heads and headers and so on i think i will have a good combo.!
[Re: 67coronetman]
#991020
05/13/11 10:42 AM
05/13/11 10:42 AM
Posts: 4,711 Moved to N.E. Tennessee
GomangoCuda
Yep, performance will be very close to the Victor intake and it will fit without a hood scoop.
[Re: 67coronetman]
#991021
05/13/11 12:55 PM
05/13/11 12:55 PM
Posts: 2,825 Sk. Canada
RemCharger
Sk. Canada
What kind of indy heads.... ?
[Re: RemCharger]
#991022
05/13/11 01:19 PM
05/13/11 01:19 PM
67coronetman
Maryville tn
Indy Sr have mild port work done to them.! They flowed 335.5 @ 700 lift
[Re: RemCharger]
#991024
05/13/11 02:35 PM
05/13/11 02:35 PM
67coronetman
Maryville tn
Well i wanted a M-1 intake but i found this one and i have heard good things about it so that is why and its a good price for now plus i will have it port matched to my heads. I can"t imagine i am loseing to much i had a edelbrock performer RPM on it before.
[Re: 67coronetman]
#991025
05/13/11 11:35 PM
05/13/11 11:35 PM
Posts: 1,400 Columbia Station, Ohio
69RTSE
Thats the intake I have on my '69 Charger. 440/auto, .040" over, 10to1 comp, iron heads with big valves, Comp Cams hydraulic .507"/.510" cam, TTI 1-7/8" headers and 3" exhaust, and a BG 750 carb. All steel car, probably about 38-3900lb race weight. Went 12.20s with slicks and 4.10s. Also went 12.80s with 3.23s and regular street tires. Good intake, no problems on the street.
[Re: 69RTSE]
#991026
05/14/11 12:04 PM
05/14/11 12:04 PM
67coronetman
Maryville tn
Thanks for the reply did you do any port work on the heads or bigger valves or intake porting at all.?
[Re: 69RTSE]
#991027
05/16/11 08:45 AM
05/16/11 08:45 AM
67coronetman
Maryville tn
I am hoping with my set up it will really wake the motor up more than with the edelbrock performer RPM intake. I keep hearing other say a single plane is no good for street use but 90% of my friends run them all the time and have been on me for some time to change and see the diff it makes so i am time will tell.!
[Re: 67coronetman]
#991028
05/16/11 11:53 AM
05/16/11 11:53 AM
Posts: 5,746 Ontario, Canada
Dodgem
Ontario, Canada
what are you trying to do Be specific. 1. you may want to look at indy's dual plane intake for standard intake port (you did not say max wedge) 2. or step up to a victor junior standard port what is street able is real suggestive TM7 is a good intake don't think there will be a big overall difference from a RPM performer?? less down low more up top kind of thing. The Indy dual plane is supposed to be the best dual plane out there.
[Re: 67coronetman]
#991029
05/16/11 11:58 AM
05/16/11 11:58 AM
Dodgem
Ontario, Canada
I'm old as dirt and never ran anything but a single plane on the street. better options now the RPM and Holley SD give the best of both worlds. The big Indy dual plane is better yet I'm told then just move right up to victor.
You still have both feet don't you??
[Re: 67coronetman]
#991031
05/16/11 03:42 PM
05/16/11 03:42 PM
Posts: 1,646 Ontario,Canada
firefighter3931
Ontario,Canada
The TM7 is an excellent manifold. When we dynoed my old 446 there were 4 intake manifolds tested ; TM7/Victor/Street Dominator/Performer Rpm The TM7 vs SD was almost identical...within 1-2 TQ/HP of each other (535hp/540tq) The Victor made 10 more hp but also pushed the peaks up higher. The RPM was down about 25hp but it did make more tq below 3000 than any of the single planes. My engine combo is very similar to yours although you have better heads than i do....My RPM's flowed right at 300cfm @ .600 valve lift. I ended up using the Street Dominator with an 850 DP using a 4200 stall & 4.10's the car ran a best of 11.68@116 with a raceweight of 4100 lbs. Assuming you have enough stall and gear the TM7 will show some nice top end improvement. I would recommend a 1in open spacer for increased plenum volume....mine liked it ! Ron
[Re: firefighter3931]
#991032
05/16/11 05:29 PM
05/16/11 05:29 PM
67coronetman
Maryville tn
Thanks so much for the reply and info. It seem other take it in a bad was when i make a comment but i do thank you for the info again.! Have a great day.
