oil question, NOT race related but Racers would know
#990968
05/12/11 03:10 PM
05/12/11 03:10 PM
Posts: 12,013 Finally a HUSKER again
Moparnut426
Hope this dosnt get moved because I know you race guys know oil.
OK so here at the shop we change ALL the oil on all emergency trucks, Fire, Rescue, and EMT trucks. Well the diesels have 200 miles on them sometimes less.
Well I run rotella t in my cummins.
The Fire chief is my friend and he told me MAKE SURE its changed, dont care on price.
Since I run Rotella in my Cummins, would you guys ever use oil with 200 miles on it in your truck?
I mean it looks new coming out. Not even black at all. I know My uncle uses some fleet oils from his fleet truck in his dailey driver cause he works for the CO-OP and send in samples.
Mind you I would NEVER use used oil but it seems a waste to throw 200 mile oil away.
Dont flame me too hard for asking a simple question.
Kasey
Re: oil question, NOT race related but Racers would know
[Re: Moparnut426]
#990970
05/12/11 03:40 PM
05/12/11 03:40 PM
Posts: 29 Washington State
lorenr
Washington State
Good question. I've been doing it for years. Some of those Cummins diesels hold 20 to 30 quarts. If your fire chief is that foolish, tell him he needs Rotella T6 and then if he'll let you have it use it for anything. Changing oil at 200 miles is probably doing more harm than good. Make sure you pre-fill the diesel oil filters especially the big ones. Freightliner told me to use synthetic and change the filter at 10,000 miles and then change oil at 20,000. Some truckers go nearly a 100,000 miles just using a regular analysis and filter change. Oil is way to expensive to change more often than necessary. Same for diesel air and fuel filters. Diesel fuel is much cleaner than it used to be.
[Re: lorenr]
#990971
05/12/11 03:48 PM
05/12/11 03:48 PM
Moparnut426
Trust me,
We tell him its foolish. He keeps on doing it though. I personally prefill every filter on my own services, and I make sure any diesel gets prefilled by my lube tech.
Kasey
[Re: Moparnut426]
#990972
05/12/11 04:29 PM
05/12/11 04:29 PM
Posts: 3,502 SOUTH JERSEY
HEMIFRED
SOUTH JERSEY
For years a normal oil change in my race car also meant the same oil went into the tow vehicle.We only used regular oil but changed it maybe 50 passes in a 12 second stocker.
You use 200 miles as the factor in determining the overall amount it was used. In something like a fire engine how many HOURS was it been used would be more relative to it's condition.
home of the Sox and Martin Hemi Duster
[Re: HEMIFRED]
#990977
05/12/11 09:40 PM
05/12/11 09:40 PM
Posts: 8,165 Left Coast
BobR
Left Coast
Absolutely correct. It's hours not miles on these kinds of vehicles. Idling can be worse than hard use.
[Re: Moparnut426]
#990978
05/12/11 09:48 PM
05/12/11 09:48 PM
Posts: 52,972 Romeo MI
MR_P_BODY
If it still has the clear-ish color... I'd put it in my diesel... it doesnt take long at all for a diesel to turn it black
[Re: Crizila]
#990980
05/12/11 11:59 PM
05/12/11 11:59 PM
Moparnut426
Hours on all heavy equipment. We used 100 hours = 3000 miles as a general conversion rule. All heavy equipment will come with an hour meter, and their ( diesel Mfg )suggested change interval will be in hours. I have never seen an oil change interval less than 200 hours except on street sweepers. Maybe the chief ment hours? 200 miles = 15 hours. Ridiculous.
Nope, Mike wants everything changed 1 time a year regardless of miles. The average this year is 200 miles, last year was 350ish. had more fire and rescue calls, and a few parades.
I am going to save all the oil out of the 3 big trucks. and send in a sample to be analized.
Kasey
[Re: Moparnut426]
#990981
05/13/11 09:59 AM
05/13/11 09:59 AM
Posts: 16,930 NC
440Jim
NC
Kasey
Once a year is not a bad call. But if you test it and the acid, particulate dust, soot, etc are fine then consider it.
200 hrs at 8 hrs/day continuous (25 days) is a lot easier on a motor oil than 200 hrs for 10 minutes here, 30 minutes there over 1 year.
[Re: 440Jim]
#990982
05/13/11 10:28 AM
05/13/11 10:28 AM
BobR
Left Coast
Kasey
200 mile 1 year old oil acid will likely be the problem if there is one.
