Re: voltage regulator....
[Re: can.al]
#990958
05/12/11 04:30 PM
05/12/11 04:30 PM
Posts: 233 WV,USA
wvmarv
WV,USA
..first cruise night Tues,a guy asks to see my engine bay,so i open the hood. ..battery acid everywhere! ..this is the second volt reg in 2 years. ..installed a Mopar 419 and all is well... 15 volts at the battery when running..should it be a bit lower?
It should be between 13.8 and 14.2 volts. 14.2 max at fast idle (2000 rpm). Anything over that will probably boil the acid in the battery. Make sure you don't over fill the battery if you are adding acid or water to it. Been a very long time since I have done any auto electric work, but for the system to charge that high you would have to bypass the regulator. See if you can find a good auto shop that works on electrical problems in your area and give them a call. Shouldn't cost much if anything to have them check it out.
[Re: can.al]
#990961
05/12/11 10:38 PM
05/12/11 10:38 PM
RapidRobert
What is the Mopar 419? 15V is too high. Fast idle/charged batt (should already have that ![](/ubbthreads/images/graemlins/blush.gif) )/lights & heater on, check voltages/drops/ground side also. Blue/green wires go to either alt field terminal. Want switched 12V "blue" to reg and T to either field terminal and green from reg to other field terminal
[Re: can.al]
#990963
05/13/11 09:21 AM
05/13/11 09:21 AM
Posts: 3,886 Lost and Spaced
bboogieart
Lost and Spaced
the first regulator went full field and pinned my ammeter a year ago..
Looks like maybe you have a bad ammeter gauge, or resintance in your bulk head, or dashboard wiring. ![](/ubbthreads/images/graemlins/shruggy.gif)
[Re: wvmarv]
#990964
05/13/11 01:00 PM
05/13/11 01:00 PM
Posts: 2,825 Sk. Canada
RemCharger
Sk. Canada
If this were true, all of the vehicles on the road right now would be melted down. ![](/ubbthreads/images/graemlins/tsk.gif)
