70 Challenger Fuel vapor line bulkhead location #990747
05/11/11 10:42 PM
05/11/11 10:42 PM
Arizona
jsully Offline OP
jsully  Offline OP
Arizona
Can someone please post a picture with dimensions showing where the holes for the fuel vapor lines (holes for bulkhead) are located on a 70 Challenger? It has a vent line on top of the fuel filler (just inside fender).
I replaced the trunk floor and extensions and did not 'see' any bulkhead when disassembling.
Thank you
Re: 70 Challenger Fuel vapor line bulkhead location [Re: jsully] #990748
05/15/11 12:10 AM
05/15/11 12:10 AM
Arizona
jsully Offline OP
jsully  Offline OP
Arizona
Re: 70 Challenger Fuel vapor line bulkhead location [Re: jsully] #990749
05/15/11 12:19 AM
05/15/11 12:19 AM
Hamtramck, PA
Alaskan_TA Offline
Fluffy Balladeer
Alaskan_TA  Offline
Fluffy Balladeer
Hamtramck, PA
Not sure what you mean by bulkhead, but it sounds like you want an in-trunk photo?
N95 or not?
Re: 70 Challenger Fuel vapor line bulkhead location [Re: Alaskan_TA] #990750
05/15/11 12:25 AM
05/15/11 12:25 AM
west kentucky
gomangoRTSE Offline
gomangoRTSE  Offline
west kentucky
I would like a pic of the vapor line set up in a 70 Challenger California car.
Re: 70 Challenger Fuel vapor line bulkhead location [Re: gomangoRTSE] #990751
05/15/11 12:30 AM
05/15/11 12:30 AM
Hamtramck, PA
Alaskan_TA Offline
Fluffy Balladeer
Alaskan_TA  Offline
Fluffy Balladeer
Hamtramck, PA
I have pictures. Somewhere.
This comes up fairly often, I'll try to get an N95 article up on HH so it stays up forever.
Until then, there are some diagrams at http://www.hamtramck-historical.com/ServiceHighlights/1970PassengerCarHighlights09.shtml
Re: 70 Challenger Fuel vapor line bulkhead location [Re: Alaskan_TA] #990752
05/15/11 06:59 AM
05/15/11 06:59 AM
Switzerland, Europe
Swiss_Robert Offline
Switzerland, Europe
I'm not sure - since I mixed it up my self last time.
The return line coming from the vapor separator (the black can between pump and carbs) does not enter into the trunk but goes back to the tank (where you should have a pick-up unit with 2 connectors).
What goes into the trunk are the lines from the ECS (or whatever it's name was) system. These are five lines, four coming from the tank (to vent it) and one going to the breather on the right valve cover.
These are two different systems. Just in case...
After all these years having a 440 I realized that this means having an attitude... and a budget.
Re: 70 Challenger Fuel vapor line bulkhead location [Re: Swiss_Robert] #990753
05/15/11 12:22 PM
05/15/11 12:22 PM
Cincinnati, Ohio
Challenger 1 Offline
Cincinnati, Ohio
These are my N95 parts on my 71 challenger, maybe it'll help some?
I learned all this from Barry's website years ago.
This fuel steup is factory for the 440/6packs and hemis, I believe. Works great with any motor with todays gas.
[image]http://[/image]
There are 3 lines on my car, one for the vent, connects the vapor stack in the trunk to the breather on the valve cover, then the other 2 are suction and return for the fuel pump.
Re: 70 Challenger Fuel vapor line bulkhead location [Re: Challenger 1] #990754
05/15/11 12:36 PM
05/15/11 12:36 PM
Hamtramck, PA
Alaskan_TA Offline
Fluffy Balladeer
Alaskan_TA  Offline
Fluffy Balladeer
Hamtramck, PA
The 1970 N95 is an ECS system.
The 1971 N95 is a NOx system.
They are not the same.
Re: 70 Challenger Fuel vapor line bulkhead location [Re: Alaskan_TA] #990755
05/15/11 04:06 PM
05/15/11 04:06 PM
Arizona
jsully Offline OP
jsully  Offline OP
Arizona
A member (Cataclysm80) on the 'Restoration' side answered my question this morning.
Check it out...
https://board.moparts.org/ubbthreads/show...e=0#Post6629582
Thank you!
Re: 70 Challenger Fuel vapor line bulkhead location [Re: jsully] #990756
05/15/11 05:23 PM
05/15/11 05:23 PM
cataclysm80 Offline
cataclysm80  Offline
Hi, Thanks for mentioning me!
Tav
