Re: urban mith [Re: dgc333] #99004
08/04/08 06:01 PM
08/04/08 06:01 PM
Changing fluid on a tranny that is not working right and have it work after the change is likely because a plugged up filter gets replaced too.
ding ding ding we have a winner.
Re: urban mith #99005
08/04/08 07:23 PM
08/04/08 07:23 PM
A Banana Republic near you.
JohnRR Offline
JohnRR  Offline
I never had a car that changing fluid would magically fix problems inside it. If it's low to being with, okay, but if fluid level is right up, I've never found changing it to help on my cars. Not saying it's impossible, just saying I never lucked out that way.
same here.
and you can add me to the list of one who had changed fluids only to need a new rebuild severla months later. Its was almost like the clutch material in the fluid was somehow keeping the clutches happy. when I removed that material and put new fluid in, all heck broke loose
Its the fluid that does it , ATF has alot of detergent like additives and putting in fresh fluid cleans out the build up and thats what causes the problems .
If one changes the fluid on scheduled intervals a trans should live a long and happy life
Re: urban mith [Re: JohnRR] #99006
08/04/08 07:32 PM
08/04/08 07:32 PM
NJ-USA
HPMike Offline
HPMike  Offline
NJ-USA
Fluid changes don't "break" transmissions.
Yes, as was stated, the high detergent properties of new fluid will sometimes cause problems, but my theory is that if all you did was change the fluid(which by the way you are really only getting approx 25-40% out with just a pan drop), and the trans went bad, then it was already done.
MB
Re: urban mith [Re: HPMike] #99007
08/04/08 07:52 PM
08/04/08 07:52 PM
Chicago illinois
ChinooK440 Offline
ChinooK440  Offline
Chicago illinois
I,ve done quite a few fuild/filter changes on very neglected trannys and they all lived afterwards just fine.
Some of them had a pan full of muck almost an 1" thick !
Re: urban mith [Re: ChinooK440] #99008
08/05/08 12:19 AM
08/05/08 12:19 AM
Not2farfromNashville, TN
Rug_Trucker Offline
Rug_Trucker  Offline
Did a flush and fill once on my van. 2-4 days later the front seal blew.
I have heard of people changing the filter and pouring the old fluid back in. That was on an old high mileage tranny.
"The only thing to do for triumph of evil is for good men to do nothing"
"NUNQUAM NON PARATUS!"
Re: urban mith [Re: Rug_Trucker] #99009
08/05/08 12:25 AM
08/05/08 12:25 AM
Overland Park, KS.
Joshs68 Offline
Joshs68  Offline
Overland Park, KS.
If it's been working for 23 years and it still is why mess with it? keep going till it breaks then just rebuild the whole thing.
Re: urban mith [Re: Joshs68] #99010
08/05/08 04:45 AM
08/05/08 04:45 AM
Marysville, O-H-I-O
70Cuda383 Offline
70Cuda383  Offline
Marysville, O-H-I-O
how many licks does it take to get to the center of a tootsie roll pop? the world may never know.
here is the problem. old transmission. high mileage. if it breaks shortly after you changed the fluid/filter, how do you know that it would have NOT broke if you did NOT change the fluid/filter?
if you have a 150K mile engine, and you change the oil, then it blows up 500 miles later...did that last oil change break your engine, or the 150K miles that were on it before you changed the oil?
**Photobucket sucks**
Re: urban mith [Re: Joshs68] #99011
08/05/08 07:57 AM
08/05/08 07:57 AM
JohnRR Offline
JohnRR  Offline
ding ding ding .... winner ..
