urban mith #98984
08/03/08 01:02 PM
08/03/08 01:02 PM
pgh pa
captaindodge Offline OP
pgh pa
That if you have not changed your trans fluid in about 23 years or so, don't do it?
Re: urban mith [Re: captaindodge] #98985
08/03/08 01:11 PM
08/03/08 01:11 PM
Texas
GoodysGotaCuda Offline
5.7L Hemi, 6spd
5.7L Hemi, 6spd
Texas
i wouldn't. my original had 120k on it, no clue when it was last changed. I changed the fluid and converter in it, it lasted about another 5000miles. Related? Possibly..
1972 Barracuda - 5.7L Hemi, T56 Magnum 6spd - https://www.facebook.com/GoodysGotaHemi
2020 RAM 1500
[img]https://i.imgur.com/v9yezP9.jpg[/img]
Re: urban mith [Re: captaindodge] #98986
08/03/08 01:15 PM
08/03/08 01:15 PM
I would
Re: urban mith [Re: RapidRobert] #98987
08/03/08 02:11 PM
08/03/08 02:11 PM
I would
+1
Re: urban mith [Re: captaindodge] #98988
08/03/08 02:13 PM
08/03/08 02:13 PM
Milwaukee, WI
In_The_Pink Offline
In_The_Pink  Offline
Milwaukee, WI
So if you haven't changed your oil in 10K mikles, you wouldn't change it either?
Re: urban mith #98989
08/03/08 02:14 PM
08/03/08 02:14 PM
S.E. South Dakota !
bigdad Offline
Still Posting A Lot
bigdad  Offline
Still Posting A Lot
S.E. South Dakota !
I had one once that it did knock the trans out of it was a old car that had sat allot so ..
Myth, hmmmmm all myths have a "little bit" of truth to them
The lips of fools bring them strife, and their mouths invite a beating.Proverbs 18:6
Re: urban mith [Re: bigdad] #98990
08/03/08 03:02 PM
08/03/08 03:02 PM
cataclysm80 Offline
cataclysm80  Offline
I think the issue here is that the new fluid cleans/knocks loose old deposits which can clog up fluid passages possibly starving portions of the tranny for fluid. Most transmission shops will not change fluid in situations like this because it is too large of a liability risk for them. They'd rather get paid to rebuild your tranny when it goes out than have to fix it for free because it went out right after they worked on it. That is where the urban myth comes from. It's tranny shops covering their own rear end. I think the best thing for you to do if your in this situation is to change the fluid yourself using a new filter, and then do it all again soon afterward to make sure all old fluid and deposits are flushed out.
Tav
Re: urban mith [Re: cataclysm80] #98991
08/03/08 03:29 PM
08/03/08 03:29 PM
Arlington, Texas
bobby66 Offline
bobby66  Offline
Arlington, Texas
I've seen old, slipping transmissions come back to life with a fluid/filter change.
Re: urban mith [Re: cataclysm80] #98992
08/03/08 03:30 PM
08/03/08 03:30 PM
Kalispell Mt.
HotRodDave Offline
HotRodDave  Offline
Kalispell Mt.
I have seen the oposite happen several times also. I have seen guys come in with there trannys slippin and replaceing the fluid will make them start working again. I have saved several of my friens tranns doing this.
I do agree about the tranny shops covering there buts. If the trans comes in for service and the fluid is old and stinky it probably means the tranny will not last real long one way or the other, if they change it and it goes out they get blamed because they just worked on it so they know from experiance it just isn't good to do it. On my personal vehicles and friends cars who have tranny issues it is quite amazeing how many time a tranny can be fixed just by changing the fluid, I always will try changing the tranny fluid first if it is just slipping. Makeing bad noises or gears not working at all are usually something else.
If I buy a car with nasty fluid I do change it and have not had one fail on me yet
Re: urban mith [Re: HotRodDave] #98993
08/03/08 03:45 PM
08/03/08 03:45 PM
Arlington, Texas
bobby66 Offline
bobby66  Offline
Arlington, Texas
Change it and adjust the bands. If there's a bunch of metal or clutch linings in the pan you might as well just drop it out and go through it.
Re: urban mith [Re: bobby66] #98994
08/03/08 04:36 PM
08/03/08 04:36 PM
It's a dry heat
gtx6970 Offline
gtx6970  Offline
It's a dry heat
Yep,,,,pull the pan and ck for debris. if it's clean you might be ok
Re: urban mith [Re: captaindodge] #98995
08/03/08 08:01 PM
08/03/08 08:01 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
I wouldn't do it unless you WANT to rebuild the trans.
2 cases of guys I work with.
One was a 76 Grand Prix a friend bought that had under 50k miles and it was 20 years old. Trans was working fine but becasue of its age his mechanic talked him into do a fluid and filter service , nothing in the pan upon removal , the trans failed a week later .
2nd , late 80's BMW 5 series , +200k miles , trans was slipping a little. No history on the fluid ever being changed, he asked my opinion of changing it, I told him that either way he was going to have to rebuild it so go for it. He changed it , it slipped worse , changed it again after a week the car made it as far as his driveway about 10 miles from where we worked, next stop the junkyard.
If it is working fine I say if it ain't broke DO NOT BREAK IT.
YMMV
Re: urban mith [Re: JohnRR] #98996
08/03/08 10:31 PM
08/03/08 10:31 PM
MN
mnguy55 Offline
mnguy55  Offline
MN
I'm not an expert but I had a GM truck with a 700R4 that slipped slightly going into third when I got it. It had about 140,000 miles on it. No idea if it was the original fluid. I changed the fluid and the slip stopped and I drove it another 15,000 before selling it with no problems.
Re: urban mith [Re: mnguy55] #98997
08/03/08 10:36 PM
08/03/08 10:36 PM
A collage of whims
topside Offline
topside  Offline
A collage of whims
Never had a problem replacing fluid & filter with something like a "barn find", but have noticed improvements afterward. By the way, it's "myth".
Re: urban mith [Re: topside] #98998
08/03/08 10:44 PM
08/03/08 10:44 PM
I had a 98 Tahoe that I bought new and changed the fluid and filter the first time at around 50K. The trans started to slip slightly and I added some trans X and it stopped slipping. I put a total of 178K on it with the untouched trans, and used it to pull trailers quite often.
Re: urban mith #98999
08/03/08 11:15 PM
08/03/08 11:15 PM
Manitoba, Canada
DaytonaTurbo Offline
Manitoba, Canada
I never had a car that changing fluid would magically fix problems inside it. If it's low to being with, okay, but if fluid level is right up, I've never found changing it to help on my cars. Not saying it's impossible, just saying I never lucked out that way.
Re: urban mith [Re: DaytonaTurbo] #99000
08/04/08 07:59 AM
08/04/08 07:59 AM
same here.
and you can add me to the list of one who had changed fluids only to need a new rebuild severla months later. Its was almost like the clutch material in the fluid was somehow keeping the clutches happy. when I removed that material and put new fluid in, all heck broke loose
Re: urban mith #99001
08/04/08 11:03 AM
08/04/08 11:03 AM
Mass
dgc333 Offline
dgc333  Offline
Mass
Changing fluid on a tranny that is not working right and have it work after the change is likely because a plugged up filter gets replaced too.
Dave Clement Pembroke, MA 03 PT Cruiser GT Turbo 99 Dakota SLT+ CC 4x4 68 Barracuda sport coupe http://home.comcast.net/~dgc333/
Re: urban mith [Re: dgc333] #99002
08/04/08 02:02 PM
08/04/08 02:02 PM
md
mopars4ever Offline
mopars4ever  Offline
md
I changed the fluid on a old beater 96 pontiac with 120,000 miles on it. The fluid smelled/ looked burnt but it shifted fine. About 500 miles later the trans started to slip until it warmed up. Mike
Re: urban mith [Re: DaytonaTurbo] #99003
08/04/08 04:58 PM
08/04/08 04:58 PM
I don't think anyone is saying that they are expecting a fluid change is going to FIX a trans problem.
The point is that the manufacturers recommend that you change the trans fluid and filter at certain intervals and more often if you tow a trailer.
The problem is when following these recommendations it seems to often create problems.
