Page 3 of 5 1 2 3 4 5
Re: small block spead port head [Re: TheBlackCar] #989514
05/11/11 02:27 PM
05/11/11 02:27 PM
detroit area
moderncylinder Offline
detroit area
based on the original listed flow numbers its nothing to get excited about,,, a "canted valve" type head should flow 40+cfm more than the numbers listed on the intake and 30-40 more on the exh
a symetrical port head means a common int and exh port, spaced at bore spacing... a spread port head means ports are spaced apart more than factory. id imagine if its a real spread port head then it may be like a tunnel port type head with a pushrod sleeve going through the center of the port
Re: small block spead port head [Re: Crizila] #989515
05/11/11 03:29 PM
05/11/11 03:29 PM
Canada
WO23Coronet Offline
WO23Coronet  Offline
Canada
Be sure not to land on your head
Re: small block spead port head [Re: johnl1961] #989516
05/11/11 03:55 PM
05/11/11 03:55 PM
Oakland, MI
dizuster Offline
dizuster  Offline
Oakland, MI
So don't get me wrong... I'm not trying to bash you, but please just take care before you start shooting from the hip about your new product.
So not that "flow" is everything, but the flow numbers posted aren't even as good as a w8/w9, and barely better (if any) then an Indy 245RP.
So be careful with your,
but ill bet this,You can make more power with my head out of the box than others ported and polish finished product!
comment.
It just makes it seem like you might not quite know what the benchmark is. A canted valve head that doesn't make any more power then a wedge head, isn't exactly going to sell like hotcakes...
Also... if you have a head to flow, why can't the pictures be posted? Something obviously exists in physical form...
Re: small block spead port head [Re: rickraw] #989517
05/11/11 03:55 PM
05/11/11 03:55 PM
Kalispell Mt.
HotRodDave Offline
HotRodDave  Offline
Kalispell Mt.
sounds interesting, i'll stick with ryan. he's the man. w-9's- [Email]359.6@700.[/Email] seeya.
I was thinking the same thing when I first saw this thread, only thing is... how much does a complete W9 set up like that run? Answer that and we will know what price he will have to shoot to beat.
Re: small block spead port head [Re: HotRodDave] #989518
05/11/11 05:17 PM
05/11/11 05:17 PM
HOUSTON,TEXAS
FIREGUY12 Offline
FIREGUY12  Offline
HOUSTON,TEXAS
Guys dont get caught in flow numbers. Port design and shape is a major part of making power. Just because one head flows more air than another does not mean it will make more power. I bet you a spread port head will make more power with comparable flow numbers. Just my
Re: small block spead port head [Re: johnl1961] #989519
05/11/11 05:52 PM
05/11/11 05:52 PM
Georgia, USA
Smallblock340 Offline
Georgia, USA
I sure hope you can produce agood head.I was running a set of w5 second gen.Ran good while they lasted ,but quality was not good. cost more to repair than they are worth and indy has quality problems also.Look forward to more info.
Re: small block spread port head [Re: FIREGUY12] #989520
05/11/11 07:27 PM
05/11/11 07:27 PM
nc
moeflo Offline
moeflo  Offline
nc
Guys don't get caught in flow numbers. Port design and shape is a major part of making power. Just because one head flows more air than another does not mean it will make more power. I bet you a spread port head will make more power with comparable flow numbers. Just my
Why would a spread port layout make more power per CFM? We've done spread port heads for customers with good results. But, there's no inherent HP advantage over symmetrical or SB2/P7 port spacing. The original spread-port heads simply minimized the differences in the long and short intake ports of the much compromised BBC design. The big power was more a result of much raised ports, and reduced valve angles. They are still a compromise as compared to a symmetrical head. That probably plays into why there are no spread-port style heads in P/S or cup racing currently. Other than to benefit intake manifold packaging, I don't know why unlike intake ports would be desirable.
Re: small block spread port head [Re: moeflo] #989521
05/11/11 07:58 PM
05/11/11 07:58 PM
Ontario Canada
MattW Offline
MattW  Offline
Ontario Canada
IE New HEMI
Re: small block spead port head [Re: HotRodDave] #989522
05/11/11 11:07 PM
05/11/11 11:07 PM
St. Paul , Mn.
tubtar Offline
tubtar  Offline
St. Paul , Mn.
Heads...... 750 on the bay.
Rockers ( T&D ) 1,200.00
Intake .....new from Ma 425.00
Offset lifters 720.00
Porting.......I don't have the final bill yet , but the intake is getting done as I type and I'll know soon enough.
Suffice to say it is in the couple grand + neighborhood with valve springs and assembly.
My flow numbers are significantly better than those posted.......especially at low to mid lift.
Now , those numbers are reputed to be out of the box , so it may flow monster numbers.
But we're talking price here.
So if it falls in the 3,500.00 neighborhood as a bolt on kit , it should be a heck of a deal.
Very Indy like in that regard.
I'll keep my eyes peeled , but I am locked into my current path and barring disaster or lottery winning , I hope to be done dropping coin on this scale for a while.
But then again.............
Re: small block spead port head [Re: tubtar] #989523
05/12/11 10:56 AM
05/12/11 10:56 AM
Grand Haven, MI
patrick Offline
patrick  Offline
Grand Haven, MI
don't forget the new pistons and camshaft you will need with this "super poly" head...
2017 Grand Cherokee Overland
Re: small block spead port head [Re: patrick] #989524
05/13/11 01:44 AM
05/13/11 01:44 AM
acworth / N. georgia - south e...
cheapstreetdustr Offline
sheez....!!!
sometimes i think some of you people would eat your own young....
what a bunch of haters...
cheapst
365" Iron J heads,,3480lbs best 1.39 60ft on SS springs.10.54,124 mph ...6.67 1/8th et.average 60fts 1.46 w/ small cam &.063 no2 pill tagged & insured
[image][/image]
Re: small block spead port head [Re: cheapstreetdustr] #989525
05/13/11 05:16 AM
05/13/11 05:16 AM
Q
Quicktree Offline
Quicktree  Offline
Q
sheez....!!!
cheapst
no wonder we don't have anything
Re: small block spead port head [Re: Quicktree] #989526
05/13/11 08:01 AM
05/13/11 08:01 AM
Grand Haven, MI
patrick Offline
patrick  Offline
Grand Haven, MI
sheez....!!!
cheapst
I was just stating the fact that when you change valve layout from in-line wedge, to a canted head, you're going to need new valves....also, with the change in head/valve goemetry, you'll need a different camshaft to get the valve timing right. 318 poly and LA cams are not interchangeable which means possibly being stuck starting with a billet core ($$)
Re: small block spead port head [Re: patrick] #989527
05/13/11 09:13 AM
05/13/11 09:13 AM
Finally a HUSKER again
Moparnut426 Offline
Moparnut426  Offline
sheez....!!!
cheapst
And lets not forget pistons. They will need a different valve relief cut in them to clear canted valve angle. Not a big deal but just more things to change, and im sure there isnt a performance "off shelf" piston so theres more expence. Unless im wrong here, and there is a set out there.
Kasey
Re: small block spead port head [Re: cheapstreetdustr] #989528
05/13/11 09:16 AM
05/13/11 09:16 AM
Texas, USA
ChrgrCuda Offline
ChrgrCuda  Offline
Texas, USA
sheez....!!!
cheapst
I always welcome new and improved designs for our Mopars. We never get any love from the aftermarket that Ford and GM guys get.
68 Cuda Notchback [Email]10.86@120[/Email] 69 Charger R/T 440/505 2009 Challenger SRT8
Re: small block spead port head [Re: Moparnut426] #989529
05/13/11 09:19 AM
05/13/11 09:19 AM
Kissimmee Fl.
dusturbd340W5 Offline
Kissimmee Fl.
sheez....!!!
cheapst
Kasey
My custom Diamonds where not much more than a shelf set.
70 duster full chassis super pro 416 CNC Indybrock heads 727 w/brake
best so far 1.212 60 6.219 in 1/8 at 110.88 9.768 at 137.81 1/4
Re: small block spead port head [Re: dusturbd340W5] #989530
05/13/11 10:08 AM
05/13/11 10:08 AM
Hilltown Pa
1967dartgt Offline
1967dartgt  Offline
Hilltown Pa
As been brought up in many past posts the mopar crowd is not into hardcore racing and doesn't want to spend the $$$ it takes to go this route. Good luck with this head hope it works out for ya I will stick with my w-9s. Well as long as yours does blow them off the map.
Brett Miller W9 cnc'd heads
STR Chassis fabraction
Re: small block spead port head [Re: 1967dartgt] #989531
05/13/11 10:14 AM
05/13/11 10:14 AM
Great Lakes Region
abodiesonly1 Offline
Great Lakes Region
Good luck and I hope the head works out for you!
I think if we had a finished product to look at and evaluate the responses may be different, hence waiting to post until the product was finished.
Re: small block spead port head [Re: Moparnut426] #989532
05/13/11 05:04 PM
05/13/11 05:04 PM
Grand Haven, MI
patrick Offline
patrick  Offline
Grand Haven, MI
sheez....!!!
cheapst
Kasey
that's what I meant, new pistons....guess I needed more caffiene...
Re: small block spead port head [Re: patrick] #989533
05/13/11 05:15 PM
05/13/11 05:15 PM
St. Paul , Mn.
tubtar Offline
tubtar  Offline
St. Paul , Mn.
Let's not confuse hating with stating.
I also welcome any new and cool developments for these little brutes.
That being said........59 degree , 48 degree , 8.90 to 9.56 deck height , X , W-2 , 5 , 7 , 8 , 9 , P-5 , P-7 etc. etc.
There is something to be said for a standard , and it has worked well for other manufacturers.
This boutique block and head phenomena is a relatively recent development for all of them and MoPar just doesn't have the numbers to justify the tooling and development like Chevrolet and to a lesser extent , Ford.
Face it , if we ( the collective we ) didn't get some perverse pleasure out of doing something different , we'd all be driving Camaros , Mustangs or God forbid , Novas.
I'll be watching this deal as it progresses and wish the people behind it nothing but the best.
But that doesn't change the reality or the nature of how things work.
That isn't hating at all.
