Re: New pistons in an old bore
[Re: Boise Chall]
#989381
05/10/11 11:37 AM
05/10/11 11:37 AM
Posts: 2,825 Sk. Canada
RemCharger
Sk. Canada
You know the answer.... I vote for just put it together. It will make 400+ hp if you tried not to. How much more do you need for your streeter?
[Re: RemCharger]
#989382
05/10/11 11:43 AM
05/10/11 11:43 AM
Posts: 75,017 U.S.S.A.
JohnRR
U.S.S.A.
I agree , maybe not the 400 HP part , just putthe 915's on it and run it as is , nice thing is it will run on 87 octane ...
[Re: Boise Chall]
#989384
05/10/11 11:59 AM
05/10/11 11:59 AM
Posts: 301 California
court9155
California
Id atleast get the rotating assembly balanced
67 charger
[Re: Boise Chall]
#989387
05/10/11 02:39 PM
05/10/11 02:39 PM
JohnRR
U.S.S.A.
Yea I knew the answer but it was a question in my head so I had to ask. I need to get this thing off the stand and in the car before I think it to death. The bottom end will stay original I'll put a whiplash cam in it with an edelbroch torker 440 intake ( that i already have ) a Holley 800 dp carb ( that I already have ) MSD 6 AL ( that I already have ) 1-7/8 headers and swap the mechanical fan for a Taurus fan. I have a 2000 stall converter in a new trans and a 9-1/4 with 3:55 gears. Any thought on what HP the motor will make ?
What did Hughes have to say about your intake and header choice with their cam ?
[Re: Boise Chall]
#989389
05/10/11 04:13 PM
05/10/11 04:13 PM
JohnRR
U.S.S.A.
When I told Hughes about the set up I planned they said it should work great, Be quick from light to light and be able to do burnouts all day long. That may have been just their sales pitch but I think I'll be happy with it. I think it's worth a shot anyway if it runs like crap I'm not out much. I really only have to buy the cam, lifters and gaskets everything else is just parts I have laying around.
Well if they said that then I guess you are good to go.
[Re: superbyrd]
#989391
05/10/11 07:57 PM
05/10/11 07:57 PM
JohnRR
U.S.S.A.
i was thinking not too fond of the intake/carb choice,but,you got the parts lying around,use 'em. it would be happier,and a broader power range with a 750 VS holley and a perfprmer RPM intake........
you are preaching to the choir , that intake is a bad choice for that engine combo but he doesn't care , so run it .
[Re: Boise Chall]
#989393
05/10/11 10:22 PM
05/10/11 10:22 PM
JohnRR
U.S.S.A.
Besides I'm not going to be drag racing it
Which is why it's a poor intake choice, you can still use the carb , a dual plane would be better. If it were a street dominator then I would be all for trying it .
When you pose questions and ask for peoples opinions ... you are getting what you asked for ... if you were just looking for people to agree with what you are going to build, using what you have, then you should state that.
[Re: JohnRR]
#989394
05/10/11 10:30 PM
05/10/11 10:30 PM
Posts: 3,142 Central NC
gch
Central NC
Nothing wrong with the carb.It would like a dual plane a lot more though.Heck,even a used performer or CH4B would be fine for less coin than an rpm. With the torker intake it would like a vacuum secondary carb best for your application IMO.It would'nt mind the low stall as much with the vacuum carb either. But hey you have it so put it together,tune it,and get a baseline.Then see how much you can pickup by trying an intake or what ever else comes along. I built my 496 with used/leftover parts except for the pistons and I chose the wrong ones for the compression I now want.It still runs pretty well.
[Re: Boise Chall]
#989398
05/11/11 06:54 AM
05/11/11 06:54 AM
Posts: 390 kentucky
superbyrd
kentucky
okie dokie. after careful inspection,making sure there is absolutely no ridge of any kind at the top of the bores, new pistons/old bore should work fine. as for running and how much HP, if your actual compression ratio comes in anywhere near 9.5 to 1, with all the parts you have stated,and sticking with only your original questions, 350 or so on a good day. should have decent torque down low,lumber/slobber it's way through the mid range,actually start moving up about 4000 rpm when it starts running out of steam,and absolutely eating gas,and spark plugs. balance won't be affected,since it won't pull hard enough on either end to have to worry about it. you asked.....................slap it together and enjoy
