Head Lights Out! 1999 Ram 1500 #989370
05/10/11 11:23 AM
05/10/11 11:23 AM
N.W. Florida
Fat_Mike Online work OP
Fat_Mike  Online Work OP
N.W. Florida
A friend had BOTH headlights go out at the same time. Checked the obvious stuff; fuses and bulbs. Where should we look next???
Re: Head Lights Out! 1999 Ram 1500 [Re: Fat_Mike] #989371
05/10/11 01:35 PM
05/10/11 01:35 PM
Mass
DAYCLONA Offline
DAYCLONA  Offline
Mass
majority of the time it's the control center, located in the column, that controls your high beam/flasher/wiper,.....once they're fried, they're done, about $100 DIY replace...
Troubleshoot the dash switch for continuity first
Re: Head Lights Out! 1999 Ram 1500 [Re: DAYCLONA] #989372
05/10/11 01:44 PM
05/10/11 01:44 PM
N.W. Florida
N.W. Florida
Thanks a bunch! That gives us a place to start. I was at a loss...
EDIT: I should have mentioned that he does have parking lights, just no headlights.
Re: Head Lights Out! 1999 Ram 1500 [Re: Fat_Mike] #989373
05/10/11 02:01 PM
05/10/11 02:01 PM
ogletownpa
3
383'D Offline
383'D  Offline
ogletownpa
my 99 1500 did that right after I bought it used . It was the high low beam switch on the column.I dont think it was used for awhile. it happened 3 or 4 times when I would switch beams. then it seemed like after a little use it cleared up because it never happened again.
Re: Head Lights Out! 1999 Ram 1500 [Re: Fat_Mike] #989374
05/10/11 02:06 PM
05/10/11 02:06 PM
Pittsburgh, PA
1970440RT Offline
1970440RT  Offline
Pittsburgh, PA
That happened to my 97 Ram. My problem was a wire that wasn't fully seated in the connector inside the column. Everytime I tilted the wheel, the lights would go on and off. Eventually they stopped working altogether. Took plastic cladding off the column and fully seated the loose wire and haven't had a problem since.
Re: Head Lights Out! 1999 Ram 1500 [Re: Fat_Mike] #989375
05/10/11 02:20 PM
05/10/11 02:20 PM
Niles , Ohio
therocks Offline
therocks  Offline
Niles , Ohio
If they are like Durangos the headlight switch is the culprit.Had mine go out on the 99 and had a few others bad at work.We had very little problems with the dimmers.Rocky
Chrysler Firepower
Re: Head Lights Out! 1999 Ram 1500 [Re: therocks] #989376
05/10/11 03:28 PM
05/10/11 03:28 PM
N.W. Florida
N.W. Florida
Thanks to all for the excellent info/history of similar problems. I'm pretty confident we'll pin it down in one of those areas. I feared this would be a wild goose chase. Doesn't sound too bad afterall... Again, thanks to all! I'll let you know how it goes.
Re: Head Lights Out! 1999 Ram 1500 [Re: Fat_Mike] #989377
05/10/11 03:46 PM
05/10/11 03:46 PM
DELAWARE
bee71mopar Offline
bee71mopar  Offline
DELAWARE
Check the headlight switch.The wires on my 96 burned.
Re: Head Lights Out! 1999 Ram 1500 [Re: bee71mopar] #989378
05/10/11 09:26 PM
05/10/11 09:26 PM
Maryland
GO_Fish Offline
GO_Fish  Offline
Maryland
And if you hook the burned wires up to a new switch, you may still have the problem (and risk damaging the new switch. There is a lot of "juice" passing through this connection, it must be clean and tight. If the connection at the switch is burned, you should fix the wire and the switch.
Another trouble spot can be where the headlight harness passes through the bulkhead connector. Same thing can happen there. Connection will corrode, then get increasingly hotter until it burns off.
Scott B. "I'm a self-made man... I started with nothing, and I still have most of it!" 68 360 rusty B'cuda 'vert (GO Fish)13.59@ 98.72 mph 69 340 GTS stock 14.18@ 95.60 mph 01 5.9L Ram 1500 Quad Cab 4x4 01 3.5L 300M 16.23@ 86.97 mph
Re: Head Lights Out! 1999 Ram 1500 [Re: 383'D] #989379
05/10/11 11:03 PM
05/10/11 11:03 PM
N.W. Florida
N.W. Florida
Well, luckily this was the culprit. Being the most simple, it's what we tried first...and it worked! Switched from hi to low a couple times and sure enough the lights came back on. Just like 383'd, his truck is used very little during the non-hunting season, and likely builds up a little resistance (of some sort) on those surfaces. While I kinda feel like a jerk for asking a question that had such a simple solution, hopefully someone else will benefit from it. Thanks once again to everyone!!!
