PST torsion bars bent... #989307
05/10/11 05:29 AM
05/10/11 05:29 AM
Erda, UT
67Charger Offline OP
Erda, UT
Is it normal for there to be ANY bend in the torsion bar? My brand new PST 1.030's have a very slight sway. I have already installed the drivers side and when grabbing the other one to replace the passenger side I removed, I had the inclination to look down the bar. I was expecting perfectly straight, but instead it looks to be "S" shaped, about 1/16" out of perfect. Is this a problem like I think it is? I leave for Silver State in 36 hours.
11.33 @ 118.46 on motor
10.75 @ 125.35 w/ a little spray
Now, high Speed Open Road Racing - Silver State Classic Challenge, Nevada Open Road Challenge, Big Bend Open Road Race
Rocky Mountain Race Week 2020, 2022 2.0, Sick Week 2023
Re: PST torsion bars bent... [Re: 67Charger] #989308
05/10/11 10:16 AM
05/10/11 10:16 AM
S.E. Michigan
ZIPPY Offline
ZIPPY  Offline
S.E. Michigan
1/16 from perfectly straight is actually quite good for a part like a torsion bar. They just aren't manufactured with a great deal of precision, and don't need to be, because the hex ends allow for a certain amount of misalignment. I have several OEM and MP bars that are slightly off from being completely straight, all work fine.
So ? No worries
Rich H.
Esse Quam Videri
Re: PST torsion bars bent... [Re: 67Charger] #989309
05/10/11 10:35 AM
05/10/11 10:35 AM
Central Oregon
Rodney Offline
Rodney  Offline
Central Oregon
Do the aftermarket T- bars have a right and left like the OEM parts?
Re: PST torsion bars bent... [Re: Rodney] #989310
05/10/11 11:19 AM
05/10/11 11:19 AM
Erda, UT
Erda, UT
EDITED FOR CLARITY
No offset hexes, but there is an "R" and "L" forged into the back of the bar. The OEM .925ish 440 bars that came out had exactly 1/2 flat of rotation, 30°.
Now to be clear, I'm talking about an S bend along the length of the bar, not a twist of one hex to the other... If it's OK, then I'll install it, otherwise today I'm driving 70 miles down to Hotchkis and dropping $400 on a set from them.
Re: PST torsion bars bent... [Re: 67Charger] #989311
05/10/11 11:26 AM
05/10/11 11:26 AM
MR_P_BODY Offline
MR_P_BODY  Offline
No offset hexes (exactly 1/2 flat of rotation, 30°) like the OEM .925ish 440 bars that came out, but there is an "R" and "L" forged into the back of the bar.
Yes that S shape is somewhat normal... that occurs
during the pre loading of the bars(the company winds
up the bar to take a pre set so they arent sagging
on the car... that gives you the 30* hex difference)
put them in
Re: PST torsion bars bent... [Re: MR_P_BODY] #989312
05/10/11 11:36 AM
05/10/11 11:36 AM
Erda, UT
Erda, UT
put them in
OK, sounds good, but like I said (although somewhat ambiguously), the new bars do NOT have offset hexes. OEM bars thaty came out do, new do not.
Looks like I'll be running them.
Re: PST torsion bars bent... [Re: 67Charger] #989313
05/10/11 11:45 AM
05/10/11 11:45 AM
MR_P_BODY Offline
MR_P_BODY  Offline
put them in
I'm suprized they dont pre load them... you may find
that the first few months you MIGHT be adjusting the
ride height... the way the bars are heat treated
will give that wavy S but usually its just a minor
sag
EDIT
I would still think they pre-loaded them but just
moved the orientation of the hex when making the bars
otherwise they wouldnt need to have a left and right
Re: PST torsion bars bent... [Re: MR_P_BODY] #989314
05/10/11 12:30 PM
05/10/11 12:30 PM
Erda, UT
Erda, UT
Thank you for putting my mind at ease. I'm guessing the no-offset is because the spring rate of these bars is about double that of the .920's so there is less preload necessary.
Re: PST torsion bars bent... [Re: 67Charger] #989315
05/10/11 01:41 PM
05/10/11 01:41 PM
So Cal
autoxcuda Online content
autoxcuda  Online Content
So Cal
At somewhere in the over 1.00" they go to no offset.
My MP .99's have offset. My MP 1.14" don't. I got decent adjustment left in my 1.14" 's.
I haven't starred down at a set of bars to have an opinion about the "S" curve you are seeing.
Re: PST torsion bars bent... [Re: 67Charger] #989316
05/10/11 02:24 PM
05/10/11 02:24 PM
Sante Fe Springs, CA
Hotchkis Offline
Hotchkis  Offline
EDITED FOR CLARITY
67Charger -
Are you sure the bar is actually curving? Those bars are tapered in the center which might give the appearence of a bend.
We would suggest calling the company from which you purchased the bars. We've never seen a curve in any of the bars we've used (our own or Firm Feel's) so we would suggest you have it checked out.
Just as a bit of Torsion Bar info for the rest of you if you're interested, most of the new high performance bars are not offset like the factory bars. The hexes are identically lined up which is better for lowered cars.
Stock Mopar bars have a 30 degree offset. This offset is what sets up the "preload" and suspension geometry. But that's for a stock spring rate.
Stiffer bars will not twist as much with the load of the car on them, so the ride height and geometry won't be right if they had the same offset. We've seen this problem with 1.16 bars on a challenger, you actually run out of suspension adjustment before the ride height is back down to normal. You need a lot less than the stock 30 degree offset.
Install new bars the way you normally would. The lower control arms will end up lining up with less angle on them. But that won't reduce your physical travel, since the bar will not twist as much under load. The stiffer bars will reduce the effective travel though, they just won't twist as much. So you can actually lower the car more (reducing the physical travel available) since you won't be using that travel.
1.03 bars will give a much more "modern" feel to the handling of your car. New cars run much higher spring rates than our old mopars, which were seriously under sprung in stock form. But it's important to match parts, you'll want to upgrade the shocks to handle the new larger bars.
Hope this helps.
Re: PST torsion bars bent... [Re: Hotchkis] #989317
05/10/11 11:31 PM
05/10/11 11:31 PM
Erda, UT
Erda, UT
Re: PST torsion bars bent... [Re: 67Charger] #989318
05/11/11 02:27 AM
05/11/11 02:27 AM
sandwich IL
sublimehemi Offline
sublimehemi  Offline
sandwich IL
received mine the other day,just checked mine and they are perfect.
70 charger ,all aluminum 528 hemi 727 cope rmvb,680hp 670 tq,full sequential holley hp efi,full hotchkis tvs,qa1 k and lowers,borgeson steering box cass viper 11.75 with cass s-trac dana 3.54
Re: PST torsion bars bent... [Re: 67Charger] #989319
05/11/11 02:34 AM
05/11/11 02:34 AM
MR_P_BODY Offline
MR_P_BODY  Offline
Never seen them look like that... I was part of the
design team that designed/built the transverse torsion
bar set up in the F and M bodies... I did all of the
bars for the pre proto's for that design
Re: PST torsion bars bent... [Re: MR_P_BODY] #989320
05/11/11 04:31 AM
05/11/11 04:31 AM
Erda, UT
Erda, UT
Well, due to lack of time and therefore options, I put them in. My rationale is the fact that a torsion bar is just a straightened out coil spring, or vice versa. The curve is nothing it won't incur during normal suspension cycling. It was NOT, however, how the factory designed them.
Hotchkis,
You guys will be getting my future business. I bought my full set of Bilsteins and a 1 3/8" front sway bar from you at MATS last month, and the fact that you took the time to chime in with some helpful info when PST wouldn't even return my call is a pretty heavy determining factor. Granted, the PST bars were 1/2 the price delivered, but I can see why.
Re: PST torsion bars bent... [Re: 67Charger] #989321
05/13/11 12:34 PM
05/13/11 12:34 PM
Hotchkis Offline
Hotchkis  Offline
67Charger – WOW! You’re not imagining that bend! We hope they’re okay and your Silver State trip goes without a hiccup.
Thanks for your business at MATS. We like being out at events like MATS. It gives us time to get personal time with our customers.
Let us know how your car works with the new shocks and sway bar! Nice quarter mile times listed with your cool ’67! DO you drive it on the street a lot?
Re: PST torsion bars bent... [Re: 67Charger] #989322
05/13/11 01:48 PM
05/13/11 01:48 PM
SO. CAL.
70blackfish Offline
70blackfish  Offline
SO. CAL.
I would get straight ones, that is not right.
Re: PST torsion bars bent... [Re: 70blackfish] #989323
05/13/11 06:57 PM
05/13/11 06:57 PM
Akron, Ohio U.S.A.
roadhazard Offline
roadhazard  Offline
Akron, Ohio U.S.A.
Was putting some bars in my Charger and had to look at them after I saw your post.
My you have little hands and feet
Re: PST torsion bars bent... [Re: roadhazard] #989324
05/14/11 02:17 AM
05/14/11 02:17 AM
Erda, UT
Erda, UT
As you can see in my other post, the Charger has been sidelined. I'll try again to contact PST and see what they have to say about them and hopefully get them to either take them back or hand pick me a pair.
