motorhome dana 60 #988822
05/09/11 12:44 PM
05/09/11 12:44 PM
ogletownpa
3
383'D Offline OP
383'D  Offline OP
ogletownpa
78 winnebago 440 dueltires. Does the rearend have any use in a musclecar. would it fit my cuda or 70 roadrunner. 58000 miles on it and the guy is scrapping it out. I pulled the 440 already to stash as well as the tranny , even though the tail shaft would need changed for car use.
Re: motorhome dana 60 [Re: 383'D] #988823
05/09/11 12:49 PM
05/09/11 12:49 PM
North Texas
O
oleman Offline
oleman  Offline
O
North Texas
Believe most of the MH's ran Dana 70's unless it is a van based.
Re: motorhome dana 60 [Re: 383'D] #988824
05/09/11 05:46 PM
05/09/11 05:46 PM
Indiana
Fury Fan Offline
Fury Fan  Offline
Indiana
You'd have to change the floating axle ends to car-style and get custom axle shafts. Need brakes, too. All doable - but there's no provision in the casting to install a pinion snubber, and that's possibly the dealbreaker unless you're running a 4-link or somehting else..
