96 Neon - Possible to swap PCM? #988635
05/09/11 02:06 AM
05/09/11 02:06 AM
Iowa
dsp Offline OP
dsp  Offline OP
Iowa
I have a 1996 Neon that may have a defective PCM. Is it possible to install a salvage yard unit as long as the replacement PCM is removed from a 1996 Neon with the same engine and transmission? I have read that the dealer must flash the replacement PCM with the VIN and mileage. Is this true? If so, how does the PCM know it has been moved from one car to another? In other words, where else is the VIN and mileage information stored?
Re: 96 Neon - Possible to swap PCM? [Re: dsp] #988636
05/09/11 02:08 AM
05/09/11 02:08 AM
Columbus, Ohio
wheelsup68dart Offline
Columbus, Ohio
You can swap them
Re: 96 Neon - Possible to swap PCM? [Re: wheelsup68dart] #988637
05/09/11 09:54 AM
05/09/11 09:54 AM
owensboro, ky
rallye73 Offline
rallye73  Offline
owensboro, ky
Programming vin and milage has more to do with 2000 and up. Just make sure that the computer has the same part numbers on it and you should be fine. The manual and auto cars use a different pcm.
