REAR DIFF QUESTIONS. #988041
05/08/11 03:06 PM
05/08/11 03:06 PM
colorado
scat340 Offline OP
scat340  Offline OP
colorado
Question one, can a clutch type carrier from a 742 with 2.76 gears be used with 3.91 gears? Question 2, can the same carrier from the 742 be used in a 489 housing? If the carrier from the 742 can be swapped into a 489 are there any speacial mods other then using the 489 specific gears? Thanks
Re: REAR DIFF QUESTIONS. [Re: scat340] #988042
05/08/11 03:08 PM
05/08/11 03:08 PM
Kirkland, Washington
Pacnorthcuda Offline
yes and yes. You would need to switch the carrier bearings to 489 type in order to fit to the 489 case though
Re: REAR DIFF QUESTIONS. [Re: Pacnorthcuda] #988043
05/08/11 05:29 PM
05/08/11 05:29 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
No , incorrect , the clutch type bearing used in the 742 must be retained to swap it to the 489 case.
Re: REAR DIFF QUESTIONS. [Re: JohnRR] #988044
05/08/11 06:43 PM
05/08/11 06:43 PM
Ah---right you are. Wasn't thinking. Hey--what happened to yesterdays engine paint thread???
