Building headers
#987898
05/08/11 12:50 AM
05/08/11 12:50 AM
I would like to give a go at building my own headers so my question is how important is it to have the tubes close to the same length? I have a 2x3 tube chassis frame and have the motor centered and will have a front coil over suspension and rack steering so I have lots of room. I will be using 2 1/8" primaries with 4" collectors.
Re: Building headers
[Re: MR_P_BODY]
#987900
05/08/11 02:42 AM
05/08/11 02:42 AM
What would be the optimum size? This is for a 493 stroker, tunnel ram,2x750 DPs.
[Re: ]
#987901
05/08/11 03:16 AM
05/08/11 03:16 AM
Posts: 3,082 St. Paul , Mn.
tubtar
St. Paul , Mn.
Hedman has kits for tube cars that are very inexpensive..........Buy the BBC kit and get the flanges elsewhere. Like here........... http://spdexhaust.com/That may be the cheapest route and the kits are virtually fool proof. Pre bent tubes....just assemble , make a few sparks and you're done.
[Re: ]
#987902
05/08/11 09:18 AM
05/08/11 09:18 AM
Posts: 52,972 Romeo MI
MR_P_BODY
RPM dictates the primary length, CI dictates the pri diameter and collector should be about 16" long... this is just a general view of the header design
[Re: MR_P_BODY]
#987903
05/08/11 11:01 AM
05/08/11 11:01 AM
Max RPM will be 6200-6500 so I'm guessing around 32"-34" for the primaries. Would this be close Mike?
[Re: ]
#987904
05/08/11 11:12 AM
05/08/11 11:12 AM
MR_P_BODY
PM me and I can run your engine in the program
[Re: FastmOp]
#987906
05/09/11 07:53 PM
05/09/11 07:53 PM
Thanks for the input guys.
