Building headers #987898
05/08/11 12:50 AM
05/08/11 12:50 AM
Anonymous OP
Anonymous OP
I would like to give a go at building my own headers so my question is how important is it to have the tubes close to the same length? I have a 2x3 tube chassis frame and have the motor centered and will have a front coil over suspension and rack steering so I have lots of room. I will be using 2 1/8" primaries with 4" collectors.
Re: Building headers [Re: ] #987899
05/08/11 01:01 AM
05/08/11 01:01 AM
MR_P_BODY Offline
MR_P_BODY  Offline
It really helps to evacuate the cyls... you might want
to go bigger on the collector... if you want PM me
and I can run your spec through my header program
Re: Building headers [Re: MR_P_BODY] #987900
05/08/11 02:42 AM
05/08/11 02:42 AM
Anonymous OP
Anonymous OP
What would be the optimum size? This is for a 493 stroker, tunnel ram,2x750 DPs.
Re: Building headers [Re: ] #987901
05/08/11 03:16 AM
05/08/11 03:16 AM
St. Paul , Mn.
tubtar Offline
tubtar  Offline
St. Paul , Mn.
Hedman has kits for tube cars that are very inexpensive..........Buy the BBC kit and get the flanges elsewhere.
Like here........... http://spdexhaust.com/
That may be the cheapest route and the kits are virtually fool proof.
Pre bent tubes....just assemble , make a few sparks and you're done.
Re: Building headers [Re: ] #987902
05/08/11 09:18 AM
05/08/11 09:18 AM
MR_P_BODY Offline
MR_P_BODY  Offline
RPM dictates the primary length, CI dictates the pri
diameter and collector should be about 16" long...
this is just a general view of the header design
Re: Building headers [Re: MR_P_BODY] #987903
05/08/11 11:01 AM
05/08/11 11:01 AM
Anonymous OP
Anonymous OP
Max RPM will be 6200-6500 so I'm guessing around 32"-34" for the primaries. Would this be close Mike?
Re: Building headers [Re: ] #987904
05/08/11 11:12 AM
05/08/11 11:12 AM
MR_P_BODY Offline
MR_P_BODY  Offline
PM me and I can run your engine in the program
Re: Building headers [Re: MR_P_BODY] #987905
05/09/11 06:32 PM
05/09/11 06:32 PM
Hot Rod Ridge
FastmOp Offline
FastmOp  Offline
Hot Rod Ridge
I built mine with premade stubs and collectors and a box of bends. There not equal length and still picked it up a tenth in the 1/8 over the fenderwell headers I had.
Re: Building headers [Re: FastmOp] #987906
05/09/11 07:53 PM
05/09/11 07:53 PM
Anonymous OP
Anonymous OP
Thanks for the input guys.
