Edit: dynamic converter snout crack. suggestions! #98763
08/02/08 08:02 PM
08/02/08 08:02 PM
Oklahoma
Mopar72Man Offline OP
Oklahoma
see below for converter pictures please
i have a 904 that was rebuilt about 15,000miles ago or so, it's been ran hard and i've been missing the small inspection plate since day one. I have some drips of atf coming from the front of the bellhousing while it is in gear, most common cause be the front inputshaft/pump seal?
I figure its that, a cracked torque converter snout (which its a ~10,000mile old Dynamic...i'd think it would be fine), or the actual pump gasket (does that really 'fail' though?
Anything I'm overlooking? Figure i should get my hands on the pump seal and start yanking the trans out. Advice?
Are there any special tools required to do just the front pump seal? Careful prying out and tapping in all thats needed?
Thanks!
72 Challenger - will be sublime, little 340 904, 8 3/4" - Under Construction
Re: 904 leak -front of bellhousing -Inputshaft/pump seal? [Re: Mopar72Man] #98764
08/02/08 08:10 PM
08/02/08 08:10 PM
n.e. pa.
65rbdodge Offline
65rbdodge  Offline
n.e. pa.
you will need a seal puller will help you get the seal out, thats about the only special too you need.
Re: 904 leak -front of bellhousing -Inputshaft/pump seal? [Re: Mopar72Man] #98765
08/02/08 09:19 PM
08/02/08 09:19 PM
yes if leaking ATF from inside the bell. hard part is seperating either the eng or trans far enough to remove the TC. You can take a screwdriver/hammer &(carefully) tap around the perimeter of the seal & drive it inward toward the center(collapsing it in other words)until it will come out if you dont have a seal puller.
Re: 904 leak -front of bellhousing -Inputshaft/pump seal? [Re: RapidRobert] #98766
08/02/08 09:58 PM
08/02/08 09:58 PM
Oklahoma
Oklahoma
thanks, picked up the seal remover from the parts store, cheap..but looks like it will do the job. taking a breather, have the rear mount and one bell bolt holding it in, so its almost out.
Re: 904 leak -front of bellhousing -Inputshaft/pump seal? [Re: Mopar72Man] #98767
08/02/08 11:24 PM
08/02/08 11:24 PM
Oklahoma
Oklahoma
There is, what seems to be a hairline fracture on the snout of my converter, it is very small. I had an issue with some dripping from the front of the bellhousing when in gear, how possible is it that this is an issue?
It is a very young converter, and what would cause this?
Re: 904 leak -front of bellhousing -Inputshaft/pump seal? [Re: Mopar72Man] #98768
08/02/08 11:29 PM
08/02/08 11:29 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
You are lucky that you caught that , the convertor needs a new snout , not sure what causes it but it seems to be something that happens to 904s
Re: 904 leak -front of bellhousing -Inputshaft/pump seal? [Re: JohnRR] #98769
08/02/08 11:30 PM
08/02/08 11:30 PM
Oklahoma
Oklahoma
what could have happened if i wasn't so "lucky"?
Re: 904 leak -front of bellhousing -Inputshaft/pump seal? [Re: Mopar72Man] #98770
08/03/08 12:05 AM
08/03/08 12:05 AM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
Broke off , took out the pump and sent trash thru the entire trans .
I found one in a core pile at the junkyard , it took me a half hour to get the convertor out of it. I just needed the bolts to redo a trans I was doing a sort of restoration to .
Re: 904 leak -front of bellhousing -Inputshaft/pump seal? [Re: JohnRR] #98771
08/03/08 12:10 AM
08/03/08 12:10 AM
Oklahoma
Oklahoma
i see where that can happen. that'd be my motivation to finally switch to a 4/5speed. Depending on dynamics reply to the situation (my guess is they'll want somewhere about $300 to fix a $650 converter), it may go back in and get babied for awhile..if it breaks, its 4spd time. No telling how long its been cracked, i hammer on it every time i take it out. Never wanted to run an auto to being with.
Re: 904 leak -front of bellhousing -Inputshaft/pump seal? [Re: Mopar72Man] #98772
08/03/08 12:16 AM
08/03/08 12:16 AM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
just do the switch now , it's out , you are crazy to put it back , besides i'm 99% that is the source of your leak , it probably is outside the lip of the seal so it's only going to leak once you put it back in .
there's a hi stall 904 convertor in the swap section
Re: 904 leak -front of bellhousing -Inputshaft/pump seal? [Re: JohnRR] #98773
08/03/08 09:45 AM
08/03/08 09:45 AM
Oklahoma
Oklahoma
Re: 904 leak -front of bellhousing -Inputshaft/pump seal? [Re: Mopar72Man] #98774
08/03/08 11:03 AM
08/03/08 11:03 AM
NEW JERSEY
AARCONV Offline
AARCONV  Offline
NEW JERSEY
that will grenade on you...not worth putting back in
Re: 904 leak -front of bellhousing -Inputshaft/pump seal? [Re: AARCONV] #98775
08/03/08 12:46 PM
08/03/08 12:46 PM
Newport, Mi
Evil Spirit Offline
Evil Spirit  Offline
Newport, Mi
Common on 904's. If you get repaired, insist on a chrome-moly pump drive. A & A sells better front pump gears, also. IMO, I would not reuse unless fixed.
Free advice and worth every penny...
Factory trained Slinky rewinder.........
Re: 904 leak -front of bellhousing -Inputshaft/pump seal? [Re: Evil Spirit] #98776
08/03/08 05:23 PM
08/03/08 05:23 PM
Today? Who Knows?
1_WILD_RT Offline
Management Trainee
1_WILD_RT  Offline
Management Trainee
Today? Who Knows?
Before doing anything else I'd be talking to Dynamic... They are usually very fair...
Re: 904 leak -front of bellhousing -Inputshaft/pump seal? [Re: 1_WILD_RT] #98777
08/03/08 06:29 PM
08/03/08 06:29 PM
Oklahoma
Oklahoma
thanks, i got the trans sitting on the mounts and bolted to the engine..decided to wait and talk to dynamic in the morning before i button things up.
Re: 904 leak -front of bellhousing -Inputshaft/pump seal? [Re: Mopar72Man] #98778
08/10/08 01:08 PM
08/10/08 01:08 PM
Oklahoma
Oklahoma
Will this crack itself cause a fluid leak from the front of the transmission? I am going to install a stock converter for the time being and want to be 100% sure this is the cause of the fluid leak.
Thanks!
