Corbin Clamp Size for SML BLK Bypass Hose??? #987611
05/07/11 01:01 PM
05/07/11 01:01 PM
Gilbertsville, PA 19525
P
Pntastar69 Offline OP
P
I ordered the corbin clamp kit from Mancini for a 66 - 69 SML BLK and the 1" bypass hose clamps are too small, won't slide over the flared fitting. The fittings on the manifold and water pump measure approx. 1 1/8" OD . The ID of the clamps I have are approx.
1 3/16". Mancini has a kit for a 70 SML BLK and a kit for a 71 - 74 SML BLK. Called Mancini and they are not sure which clamps are correct. Apparently I have the later water pump w/the larger nipple.
I need the next size up clamps. Anyone have an idea on which kit has the correct size bypass hose clamps?
Re: Corbin Clamp Size for SML BLK Bypass Hose??? [Re: Pntastar69] #987612
05/07/11 08:49 PM
05/07/11 08:49 PM
The '70 up main bypass nipple(s) are the same so there must b some other diff on what Mancini's kits have in them. I'd see if their guy would pull both kits & open them while you are on the phone EDIT been buggin me, why did you order the pre '70 kit, do you have the pre '70 iron pump on a later '70/up tim cover/eng?
