Hemi Oil Pan/Pickup Question #987484
05/07/11 09:31 AM
05/07/11 09:31 AM
CLE Ohio
N
N95Hemi Offline OP
N95Hemi  Offline OP
N
CLE Ohio
I'm putting the stock oil pan/pickup on a 70 Hemi. Bought what I thought were the correct pieces (1/2" pickup). Went to install and have intereference. Either the pickup is too long or the pan is too short. Can someone provide the correct height/depth of a factory stock hemi oil pan. Thanks
Re: Hemi Oil Pan/Pickup Question [Re: N95Hemi] #987485
05/07/11 09:40 AM
05/07/11 09:40 AM
IN
ahy Offline
ahy  Offline
IN
Not sure on the exact depth (5 - 5 1/2") but I'd add the stock style pickup is supposed to touch the bottom of the pan. The pickup has a shroud that rests on the pan bottom to hold the pickup screen off the bottom a little to allow flow. It sort of a failsafe design so the system still works if the piclup moves around or the pan bottom gets bent.
I used Mancini's pan/pickup kit and it worked out fine.
Re: Hemi Oil Pan/Pickup Question [Re: ahy] #987486
05/07/11 09:50 AM
05/07/11 09:50 AM
Wanted to ask if you have the OE pieces to compare or is this from scratch? May need to tap the hole deeper w an NPT tapered tap or rethread the pickup more
Re: Hemi Oil Pan/Pickup Question [Re: N95Hemi] #987487
05/07/11 09:56 AM
05/07/11 09:56 AM
Moved to N.E. Tennessee
GomangoCuda Offline
GomangoCuda  Offline
It would be helpful to know how much interference there is.
Re: Hemi Oil Pan/Pickup Question [Re: RapidRobert] #987488
05/07/11 09:59 AM
05/07/11 09:59 AM
CLE Ohio
N
N95Hemi Offline OP
N95Hemi  Offline OP
N
CLE Ohio
Its from scratch. Bought the car last year from Cali. Very close to a survivor except it had a deep sump pan (welded maybe 8 quart). Want to make it all as stock as possible. Just for fun I already had the gaskets and tray gooped up and ready to go. Not a fun cleanup. Thanks
Re: Hemi Oil Pan/Pickup Question [Re: N95Hemi] #987489
05/07/11 10:00 AM
05/07/11 10:00 AM
CLE Ohio
N
N95Hemi Offline OP
N95Hemi  Offline OP
N
CLE Ohio
About 3/4" interference...
Re: Hemi Oil Pan/Pickup Question [Re: N95Hemi] #987490
05/07/11 10:03 AM
05/07/11 10:03 AM
I'm assuming w the other pickup that the block was threaded deep enough for a snug engagement so I'd get a die & cut more threads on the pickup as w you going together (rather than a mockup) you wouldn't want to have to deal w shavings in the block pickup hole
Re: Hemi Oil Pan/Pickup Question [Re: N95Hemi] #987491
05/07/11 10:20 AM
05/07/11 10:20 AM
GomangoCuda Offline
GomangoCuda  Offline
A tap and/or die is not going to fix that.
Maybe pictures of the pan and pickup would show either the wrong pickup or the wrong pan or even both wrong.
Does the pan look like this?
Re: Hemi Oil Pan/Pickup Question *DELETED* [Re: GomangoCuda] #987492
05/07/11 10:25 AM
05/07/11 10:25 AM
GomangoCuda Offline
GomangoCuda  Offline
Post deleted by GomangoCuda
Re: Hemi Oil Pan/Pickup Question [Re: GomangoCuda] #987493
05/07/11 01:49 PM
05/07/11 01:49 PM
Memphis
HemiRick Offline
HemiRick  Offline
Memphis
That straight pickup tube will NOT work with the baffled pan. The baffled pan requires a pickup tube with a dog leg in it.
Take care,
Rick
68 Coronet R/T 440 & 68 Charger 528 Hemi,and 5 Challengers! 6 cyl, 318, 360, 383, 451
Re: Hemi Oil Pan/Pickup Question [Re: HemiRick] #987494
05/07/11 02:39 PM
05/07/11 02:39 PM
GomangoCuda Offline
GomangoCuda  Offline
Guess the picture was misnamed.
Re: Hemi Oil Pan/Pickup Question [Re: GomangoCuda] #987495
05/07/11 03:04 PM
05/07/11 03:04 PM
Prospect, PA
BSB67 Offline
BSB67  Offline
Prospect, PA
If what you have pictured is the baffled pan, I've never had a problem with the straight PU hitting the pan baffle. Being too long and hitting the bottom, that is a different story.
Re: Hemi Oil Pan/Pickup Question [Re: BSB67] #987496
05/07/11 03:21 PM
05/07/11 03:21 PM
GomangoCuda Offline
GomangoCuda  Offline
I have been looking all over for a picture of a dog leg hemi pickup for this pan, Everyone on the internet shows the straight pickup that I originally posted. Which is it? I am not going to pull my pan off to see and I honestly don't remember which style it was. Anyone have a picture that they know for sure is correct?
Re: Hemi Oil Pan/Pickup Question [Re: GomangoCuda] #987497
05/07/11 03:43 PM
05/07/11 03:43 PM
CLE Ohio
N
N95Hemi Offline OP
N95Hemi  Offline OP
N
CLE Ohio
Yes that looks like the pan. I'll post pics of the pan and pickup when I get back to the garage.
Re: Hemi Oil Pan/Pickup Question [Re: GomangoCuda] #987498
05/07/11 06:22 PM
05/07/11 06:22 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
That Hemi pan uses a STRAIGHT pickup tube.
OP did you just put the pickup in hand tight ?
Re: Hemi Oil Pan/Pickup Question [Re: N95Hemi] #987499
05/07/11 06:30 PM
05/07/11 06:30 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
You might have a '66-'69 pan and a 70-'71 pickup which is about that much longer for use in the deeper '70-'71 pan.
