Re: 440 and tranny from a motor home
[Re: mopar rookie]
#98752
08/02/08 07:54 PM
08/02/08 07:54 PM
Posts: 25,849 Rio Linda, CA
John_Kunkel
Rio Linda, CA
The 440 was used in many '72 motorhomes, Winnebego and Dodge in particular.
The flat pad in front of the intake manifold will have the displacement stamped.
Many motorhome 727's have a short tailhousing with a parking brake; can't be used in a passenger car without changing the tail.
[Re: John_Kunkel]
#98753
08/02/08 09:02 PM
08/02/08 09:02 PM
Posts: 12,291 Kent, Wa
340SHORTY
Truck Nut
Truck Nut
Kent, Wa
my 72 A class Winnie had a 413 ind,, a friends 74 A class Winnie had a 440....
I am truckless..
[Re: mopar rookie]
#98755
08/03/08 01:34 AM
08/03/08 01:34 AM
Posts: 4,861 Riverside, Ca
R70RUNNER
Riverside, Ca
Just drug home a 72 413 and 727, free for the effort. Forged crank.. If it's a 440 Id say it's worth it. The trans should have a 4 gear planetary (John K should be albe to confirm) Heads maybe scarp value only depending.
Current cars: 2000 Dak Quad Cab, 2012 Challenger,1970 Road Runner, 1994 Firehawk
1966 Coronet post sedan, 1988 Corvette, 2005 Magnum RT all SOLD
R70RUNNER<---VP Inland Empire Chapter of the MPM
[Re: Reggie]
#98758
08/04/08 01:10 AM
08/04/08 01:10 AM
R70RUNNER
Riverside, Ca
The 413 I have has no numbers that I can see on the oil pan rail pad.. and the block had splash shields that prevented seeing casting numbers without removal. The Dist pad is best source IMO. Mine is as follows HT413 (I'm still learning on this motor) I assume H=72 T=truck 413=413 Guy's info checks out on my 413 thick dampner and holley carb for a '72 Anyone have the stock compression hight on these 413 pistons? Sorry off topic
