Properly adjusting Challenger Gear Box #98742
08/02/08 06:53 PM
08/02/08 06:53 PM
Harrisburg Pa. 17112
moparmikethree Offline OP
I want to take out as much play as possible in the (Steering) Gear Box. How do you do it properly, I want to eliminate as much play as possible.
Re: Properly adjusting Challenger Gear Box [Re: moparmikethree] #98743
08/02/08 07:29 PM
08/02/08 07:29 PM
Nobody knows how?
Re: Properly adjusting Challenger Gear Box [Re: moparmikethree] #98744
08/02/08 10:00 PM
08/02/08 10:00 PM
East Aurora (Buffalo) NY
RoadRunner Offline
RoadRunner  Offline
There is a procedure in the factory manual. There are two parts you need to do. The onse adjustment is easy to get to. If anything, here is a bump.
68 Road Runner (383/4speed, post car w/decor pkg) - Major Project
69 Road Runner w/472 Hemi & 4 speed.
70 Challenger R/T SE EF8 w/ V9J, U - A32 - Major Project
2023 Ford Mach 1
Re: Properly adjusting Challenger Gear Box [Re: RoadRunner] #98745
08/03/08 09:57 AM
08/03/08 09:57 AM
Britton, MI
GTXWagon Offline
GTXWagon  Offline
Britton, MI
Manual or power steering ???
Re: Properly adjusting Challenger Gear Box [Re: moparmikethree] #98746
08/03/08 12:38 PM
08/03/08 12:38 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
Nobody knows how?
it can only be adjusted so much , if you have a lot of free play the only way to fix it is to replace it , i adjusted a worn durango box and it actually made the thing dangerous to drive .
Re: Properly adjusting Challenger Gear Box [Re: moparmikethree] #98747
08/03/08 05:05 PM
08/03/08 05:05 PM
POWER STEERING, I THINK TO LOOSEN THE JAMB NUT AND TIGHTEN THE ALLEN screw. But how much
Re: Properly adjusting Challenger Gear Box [Re: moparmikethree] #98748
08/03/08 05:41 PM
08/03/08 05:41 PM
Grand Prairie,Texas
stumpy Online content
stumpy  Online Content
Grand Prairie,Texas
Tighten it a little at a time. If the steering wheel won't self center easily then you've gone too far. Just remember power steering will have slop with the engine off. BTW is your shaft coupler sloppy or tight?
