Fuel cell cap help #987337
05/06/11 09:59 PM
05/06/11 09:59 PM
NC USA
71mopardude Offline OP
I don't get it?
I don't get it?
NC USA
Hey guys i need our help! I have an unknown fuel cell ( no name on it anywhere) it is around a 15 gallon, it is black plastic .. Im looking to get a new cap for it ( called jegs and summit they dont have measurements ) but heres my info .. it is a 12 bolt flush mount .. the cap i have now is red in color .. the outer mounting ring diameter is 6 inches the cap is about 3.5 inches with a taper ... if it matters the tank is a bottom sump... so if mine is the same as yours can you tell me what brand it is so i can order a new one !!
Re: Fuel cell cap help [Re: 71mopardude] #987338
05/07/11 12:01 AM
05/07/11 12:01 AM
Land of the Brave, Home of the...
63CandyMatic Offline
Is the current cap not functional, stiff, or is the plastic tab broke off. I just had to wrestle mine recently to get it open, same style of tank from what it sounds like.
Re: Fuel cell cap help [Re: 71mopardude] #987339
05/07/11 12:05 AM
05/07/11 12:05 AM
MR_P_BODY Offline
MR_P_BODY  Offline
Check the Jaz web site, they sell parts for the cells
Re: Fuel cell cap help [Re: 71mopardude] #987340
05/07/11 12:07 AM
05/07/11 12:07 AM
superstreet1896 Offline
Sounds like a Jaz. thats what i have and sometimes it can be hard to get on and off.
Re: Fuel cell cap help [Re: 71mopardude] #987341
05/07/11 12:16 AM
05/07/11 12:16 AM
Ambridge, Pa.
rickraw Online content
rickraw  Online Content
Ambridge, Pa.
hey. i think ur cap is the same as mine. check out summit, sum-290198. seeya.
Re: Fuel cell cap help [Re: rickraw] #987342
05/07/11 12:43 AM
05/07/11 12:43 AM
NC USA
I don't get it?
I don't get it?
NC USA
wish they just gave out demensions !! too easy that way lol it does look like the summit or the
Jaz one .... grrrrrr what to do ... my doesnt seal properly tried replacing the o ring but cant find the correct one also seems like it should tighten down better when it locks
Re: Fuel cell cap help [Re: 71mopardude] #987343
05/07/11 01:01 AM
05/07/11 01:01 AM
Ambridge, Pa.
Ambridge, Pa.
hey. i'd say the 1 from summit is the 1 u need. they also have the rubber seal too. if it don't fit, send it back. i put some vasaline on the seal, opens easier. seeya.
Re: Fuel cell cap help [Re: rickraw] #987344
05/07/11 10:02 AM
05/07/11 10:02 AM
NC USA
I don't get it?
I don't get it?
NC USA
Ordered it ...
Re: Fuel cell cap help [Re: superstreet1896] #987345
05/08/11 12:18 PM
05/08/11 12:18 PM
Southwestern Ontario Canada
racealittle Offline
racealittle  Offline
I have had this issue a number of times with fuel cells.
A pair of pliers about the size of the flats on the locking ring, and some finesse to the flats will make it work better than new.
Too many cars, too many parts, too little coin, too little space to work in, too little time left to make it all happen! Update: down to one ride, still too many parts, a little more jingle in the pocket, gaining space, and it's going to happen this year!
Re: Fuel cell cap help [Re: rickraw] #987346
05/11/11 06:15 PM
05/11/11 06:15 PM
NC USA
I don't get it?
I don't get it?
NC USA
Thanks for the help .. it was the correct one !!
