Re: 71 RR and 73 Charger SE rear seat interchange?
[Re: badblubeee]
#987184
05/06/11 05:59 PM
05/06/11 05:59 PM
Posts: 1,168 Vancouver, WA
MoparMarq
Vancouver, WA
Not positive, but pretty sure that seat bottom and seat backs are the same size. Though, as you said, fabric patterns are different. Rear glass the same, also. Door glass the same. 1/4 glass may or may not be different. Rear shelf the same, I believe. Rear 1/4 interior panels lowers MAY be the same, uppers almost certainly will not swap. Door panels will fit, upper and lower.
I have a driver's door glass, if your buddy needs one, BTW.
[Re: MoparMarq]
#987185
05/06/11 07:14 PM
05/06/11 07:14 PM
Posts: 3,106 Ridgeland Wi
mopars_1
Ridgeland Wi
yes, the seats will interchange. I think there was a little different spring arangment maybe? also, the rear lower door panels are slightly different, somewhere in there they had molded in arm rest pads.
1971 Plymouth Duster 340 auto 1937 Plymouth PT50 1969 Dodge Dart Swinger 340 4 speed 2013 Ram laramie 2500 hemi 2008 Harley FLSTSB springer
[Re: mopargem]
#987187
05/07/11 01:30 PM
05/07/11 01:30 PM
Posts: 1,780 Springfield Oregon
badblubeee
super gas
super gas
Springfield Oregon
Thanks for the replys-I was pretty sure it would fit but ya never know. The guy is going to reupholster so the material doesn't matter. Dave Yea, my son was going to "restore" it! clueless
[Re: badblubeee]
#987188
05/07/11 03:30 PM
05/07/11 03:30 PM
Posts: 6,096 Valencia, España
NachoRT74
Valencia, España
THIS IS ON BUCKETS SETUP:
70/71 foams and 72/74 are diff foams of course, covers too to fit on foams ( same years )
SEAT BACK changed on mid 71 production line, from a large release button and metallic hinge covers to a one piece seat back panels, covering hinges and smaller release back button. This of course makes a diff back frame, back panel, back release system. So you'll need to take care about that when finding replacements if needed.
tracks are the same.
now, DUNNO if benchs got somekind of differences like these
