PPG Delstar paint for engine #987139
05/06/11 01:58 PM
05/06/11 01:58 PM
PA
BTTG Offline OP
BTTG  Offline OP
PA
What product is used to thin PPG Delstar paint?
was going to paint my engine with it using a disposable Preval sprayer. this method was said to work well here if the paint is thinned 30%.....just need to know how to prepare the paint to spray (i.e., what product(s) I will need in addition to the can of paint).
can't find the info on line or from the PPG website.
Re: PPG Delstar paint for engine [Re: BTTG] #987140
05/06/11 02:02 PM
05/06/11 02:02 PM
Cincinnati, Ohio
Challenger 1 Offline
Cincinnati, Ohio
enamel reducer, I always add hardner to the paint, so it flows out.
I would not use it on a engine, too expensive and won't handle heat well.
Re: PPG Delstar paint for engine [Re: BTTG] #987141
05/06/11 02:02 PM
05/06/11 02:02 PM
northwest USA
N
NANKET Offline
NANKET  Offline
N
northwest USA
look at this page, you need hardener and reducer. I use Deltron on engines and it is excellent.
http://www.tcpglobal.com/docs/ppgdarp.pdf
Re: PPG Delstar paint for engine [Re: BTTG] #987142
05/06/11 03:00 PM
05/06/11 03:00 PM
Slidell, La.
doctor_mopar Offline
Slidell, La.
You need Acrylic Enamel Reducer, not Enamel Reducer. I painted a 383, 15 years ago with Delstar without use of the hardner, and it still looks great. It is debateable whether or not to use a hardener. It is not required to make the paint cure. It does increase duarability and shine, and allow for polishing as on the exterior of a car. The finish with the hardner is really too shiny to look correct on an engine, and causes the paint to be somewhat brittle.
------------------------ It doesn't matter what you do.........As long as you look good doing it !
Re: PPG Delstar paint for engine [Re: doctor_mopar] #987143
05/06/11 06:24 PM
05/06/11 06:24 PM
North Dakota
440abody Offline
440abody  Offline
North Dakota
Used for years and have no problem. Holds gloss well if lyou use hardener. Just make sure your engine is clean, clean, clean, just as you would with any quality paint job.
73 Dart Swinger 440/727 8.75 w/3.55's
34 Ford 3w coupe with a soon to be 1958 392HEMI!
Re: PPG Delstar paint for engine [Re: 440abody] #987144
05/06/11 07:12 PM
05/06/11 07:12 PM
Wisconsin
Aero426 Offline
Aero426  Offline
Wisconsin
Use the hardener and Delstar works fine on an engine.
Re: PPG Delstar paint for engine [Re: Aero426] #987145
05/06/11 11:34 PM
05/06/11 11:34 PM
Phila Pa
scatpacktom Offline
scatpacktom  Offline
Phila Pa
It's all I use on my engines
