Big block oil pan gasket - silcone w/steel inserts? #986955
05/05/11 09:30 PM
05/05/11 09:30 PM
Warren, MI
71TA Offline OP
71TA  Offline OP
Warren, MI
Who sells these? I bought one about 2 years ago at a swap from a vendor in Norfolk, OH and can't find it now. was gray in color. Silicone. had the steel inserts at each bolt hole. a real quality piece. Think it was like $40 or $50.
PS Anyone used one? Comments?
Re: Big block oil pan gasket - silcone w/steel inserts? [Re: 71TA] #986956
05/05/11 11:24 PM
05/05/11 11:24 PM
Warren, MI
71TA Offline OP
71TA  Offline OP
Warren, MI
THAT took a lot of searching. It was from Flatout Racing.
https://www.flatoutgroup.com/showphoto.aspx?p=5020feature.gif
Next qusetion. Who make a BB valve cover gasket like this? Silicone with the steel inserts.
Re: Big block oil pan gasket - silcone w/steel inserts? [Re: 71TA] #986957
05/06/11 12:25 AM
05/06/11 12:25 AM
Eagle, Idaho
Neil Offline
The Doctor is in.
Neil  Offline
The Doctor is in.
Eagle, Idaho
I'm not sure they are available for BB Mopars? I know they have them for smallblocks though.
Check Mancini Racing or Summit????
Re: Big block oil pan gasket - silcone w/steel inserts? [Re: 71TA] #986958
05/06/11 12:52 AM
05/06/11 12:52 AM
Northern Indiana
Dunnuck Racing Offline
Northern Indiana
Moroso makes some valve cover gaskets like that,they are a little thicker than the MP small block ones.They have them for big and small blocks.
Fel Pro also makes an oil pan gasket like you are looking at.
Keith
Re: Big block oil pan gasket - silcone w/steel inserts? [Re: 71TA] #986959
05/06/11 02:37 PM
05/06/11 02:37 PM
northwest USA
N
NANKET Offline
NANKET  Offline
N
northwest USA
Did you use this gasket yet? How did you like this gasket? At .140 thick, with 2 gaskets and a windage tray would make for some long bolts.
