Re: Which is harder on an engine?
[Re: desomod]
#986698
05/06/11 07:27 PM
05/06/11 07:27 PM
Posts: 30,424 Florida STAYcation
dOrk !
The village idiot's idiot
Florida STAYcation
It seems you would have to use quite a bit of starting fluid to do harm to the cylinder walls. The all a pain in the a** with the shaker setup to even see the carbs!
x 2 .... NO harm on the cyl walls uNless you empty the whole can in there.
With your combo ... just get an electric fuel pump and fill-the carbs with a flick of a switch ..
[Re: RapidRobert]
#986700
05/07/11 06:58 AM
05/07/11 06:58 AM
Posts: 1,074 detroit, mi
POS Dakota
detroit, mi
A guy stated once (on here) that starting fluid is extremely harmful and he explained why (dont remem what he said) & called it "liquid sand in a can".
It's a very strong degreaser so yeah, it will wash the oil off and if used excesively can be a problem.
But seriously, one or two quick bursts arent going to cause a problem. It's when people give a big long spray of it that you can get a problem. It also evaporates very quick so used in a small quantity it's suspended in the air in large part I would think.
A couple quick shots of gas is a great "alternative" solution!
[Re: dOrk !]
#986703
05/07/11 10:48 AM
05/07/11 10:48 AM
Posts: 923 Missouri
convertriple
super gas
super gas
Missouri
Thanks for the input. On my other car with a Holly carb, it's no problem to fill the bowl through the vent with a little funnel. On the Carter (Eddy) carbs, there is no place to do that without pulling the top of the carb off.
I use a contact lens solution bottle to fill the vent tube on the primary side. Works good, though I can't say how it is on an edelbrock.
[Re: B5 Bee]
#986704
05/07/11 10:59 AM
05/07/11 10:59 AM
Posts: 21,823 Kirkland, Washington
Pacnorthcuda
Starting fluid isn't for starting motors, along with a match it's used for seating tire beads to rims.
Wrong. Its for anesthetising (sp) Spiders. Knock them out, play with them, then let them come to.
They never look at you the same afterwards though....
[Re: Pacnorthcuda]
#986705
05/07/11 12:02 PM
05/07/11 12:02 PM
dOrk !
Florida STAYcation
NOT a whole lot TO DO in WA ...when it is raining ...HUH ? ..
[Re: dOrk !]
#986706
05/07/11 12:17 PM
05/07/11 12:17 PM
Pacnorthcuda
when you're dealing with eight legs the possibilities are endless.
[Re: GomangoCuda]
#986708
05/07/11 02:35 PM
05/07/11 02:35 PM
Posts: 11,632 SHELBY TWP,,MICHIGAN
72N96RR
I LOVE WEDGIES
I LOVE WEDGIES
I have an Eddie on my 72 440 motor and I started the car every three weeks or so all winter long without an issue ever..Pump the pedal once or twice and it fired...Im talking zero degree days too..
1972 Road Runner / GTX 440 4spd Dana 3.54 Just about to turn 26K original miles..
A boat, a GMC truck, some Craftsman Tools, LOTS of Zombie Protection, and a few Goldfish..
If you love someone set them free.. If they come back it means nobody else wanted them either..!!
[Re: GomangoCuda]
#986710
05/07/11 03:32 PM
05/07/11 03:32 PM
dOrk !
Florida STAYcation
One time we had a wasp pestering us as we worked on a car. I went to the work bench to see if we had any thing to kill it with. Starting fluid knocked him right out of the sky. Didn't even kick his legs after he hit the concrete. If he had I would have thrown a match at him.
.... I wonder if this would work against a 64PEST ?
[Re: 1_WILD_RT]
#986711
05/07/11 10:18 PM
05/07/11 10:18 PM
72N96RR
I LOVE WEDGIES
I LOVE WEDGIES
Not allot of evaporation taking place on a zero degree day... This was much less of an issue when we had real gasoline... The needs of a carburated vehicle are not given an thought when blending the formulations used today...
You nailed it with the REAL GAS comment..
