Re: Which is harder on an engine?
[Re: desomod]
#986680
05/05/11 05:26 PM
05/05/11 05:26 PM
Posts: 299 East Brunswick, NJ
finadk
East Brunswick, NJ
Really? I have a 600 CFM 1406 on a small block that sits for months and months at a time, and untouched all winter. I pump the gas 6-7 times turn the key and it fires right up every time. Never had to crank it more than 20 seconds and never used starting fluid.
Scott
Scott
1956 Dodge Custom Royal Lancer (408 Stroker, 4 Wheel Disc Brakes, Rack & Pinion, 6 speed)
2002 Dodge Ram 1500 Quad Cab
1976 Corvette
[Re: desomod]
#986682
05/05/11 06:16 PM
05/05/11 06:16 PM
Posts: 6,167 Maryland
GO_Fish
Maryland
Once the oil pressure comes up, you should have little wear while cranking. Probably a bigger issue would be wearing out the starter.
I read once years ago that for every doubling of rpm's, you quadruple the wear. So at 8,000 rpms theres a whole lot more wear going on than at cranking rpms (again, once you have oil pressure).
Scott B.
"I'm a self-made man... I started with nothing, and I still have most of it!"
68 360 rusty B'cuda 'vert (GO Fish)13.59@ 98.72 mph
69 340 GTS stock 14.18@ 95.60 mph
01 5.9L Ram 1500 Quad Cab 4x4
01 3.5L 300M 16.23@ 86.97 mph
[Re: desomod]
#986689
05/06/11 04:52 PM
05/06/11 04:52 PM
Posts: 30,424 Florida STAYcation
dOc !
The village idiot's idiot
Florida STAYcation
Thanks for the input. On my other car with a Holly carb, it's no problem to fill the bowl through the vent with a little funnel. On the Carter (Eddy) carbs, there is no place to do that without pulling the top of the carb off.
The TQ carb is probably the WORSE ...as far as evap. Just go to the DOLLAR STORE and get a pair of those mustard/ketchup squirt bottles.
And YES ...I would not want to crank and CRANK ..... NOT good for the starter OR cam. uNless you have a roller cam.
[Re: desomod]
#986690
05/06/11 04:53 PM
05/06/11 04:53 PM
RapidRobert
A guy stated once (on here) that starting fluid is extremely harmful and he explained why (dont remem what he said) & called it "liquid sand in a can".
[Re: desomod]
#986691
05/06/11 05:05 PM
05/06/11 05:05 PM
Posts: 5,388 Pikes Peak Country
TC@HP2
Pikes Peak Country
Actually, there is. The vents are are smallish, rectangular holes right next to the rod covers.You can get gas in the bowl that way, but will need the aforementioned squirt bottle to do it.
[Re: Dean_Kuzluzski]
#986693
05/06/11 05:10 PM
05/06/11 05:10 PM
Posts: 4,179 California
mickm
California
I was hoping someone would bring this up...........old schoolers I know call it "very caustic" and generally discourage the use of it if you don't have to.
that is what i have heard as well.
i just have a little glass bottle filled with gas, and dump a bit down the carbs before firing it if it has sat for a while. that at least gets an initial few seconds of running and primes the carbs. then i don't have to crank nearly as much to get it going.
[Re: desomod]
#986698
05/06/11 07:27 PM
05/06/11 07:27 PM
dOc !
Florida STAYcation
It seems you would have to use quite a bit of starting fluid to do harm to the cylinder walls. The all a pain in the a** with the shaker setup to even see the carbs!
x 2 .... NO harm on the cyl walls uNless you empty the whole can in there.
With your combo ... just get an electric fuel pump and fill-the carbs with a flick of a switch ..
[Re: RapidRobert]
#986700
05/07/11 06:58 AM
05/07/11 06:58 AM
Posts: 1,074 detroit, mi
POS Dakota
detroit, mi
It's a very strong degreaser so yeah, it will wash the oil off and if used excesively can be a problem.
But seriously, one or two quick bursts arent going to cause a problem. It's when people give a big long spray of it that you can get a problem. It also evaporates very quick so used in a small quantity it's suspended in the air in large part I would think.
A couple quick shots of gas is a great "alternative" solution!
[Re: dOc !]
#986703
05/07/11 10:48 AM
05/07/11 10:48 AM
Posts: 923 Missouri
convertriple
super gas
super gas
Missouri
I use a contact lens solution bottle to fill the vent tube on the primary side. Works good, though I can't say how it is on an edelbrock.
[Re: B5 Bee]
#986704
05/07/11 10:59 AM
05/07/11 10:59 AM
Posts: 21,819 Kirkland, Washington
Pacnorthcuda
Starting fluid isn't for starting motors, along with a match it's used for seating tire beads to rims.
Wrong. Its for anesthetising (sp) Spiders. Knock them out, play with them, then let them come to.
They never look at you the same afterwards though....
[Re: Pacnorthcuda]
#986705
05/07/11 12:02 PM
05/07/11 12:02 PM
dOc !
Florida STAYcation
NOT a whole lot TO DO in WA ...when it is raining ...HUH ? ..
[Re: dOc !]
#986706
05/07/11 12:17 PM
05/07/11 12:17 PM
Pacnorthcuda
when you're dealing with eight legs the possibilities are endless.
[Re: GomangoCuda]
#986708
05/07/11 02:35 PM
05/07/11 02:35 PM
Posts: 11,632 SHELBY TWP,,MICHIGAN
72N96RR
I LOVE WEDGIES
I LOVE WEDGIES
I have an Eddie on my 72 440 motor and I started the car every three weeks or so all winter long without an issue ever..Pump the pedal once or twice and it fired...Im talking zero degree days too..
1972 Road Runner / GTX 440 4spd Dana 3.54 Just about to turn 26K original miles..
A boat, a GMC truck, some Craftsman Tools, LOTS of Zombie Protection, and a few Goldfish..
If you love someone set them free.. If they come back it means nobody else wanted them either..!!
[Re: GomangoCuda]
#986710
05/07/11 03:32 PM
05/07/11 03:32 PM
dOc !
Florida STAYcation
One time we had a wasp pestering us as we worked on a car. I went to the work bench to see if we had any thing to kill it with. Starting fluid knocked him right out of the sky. Didn't even kick his legs after he hit the concrete. If he had I would have thrown a match at him.
.... I wonder if this would work against a 64PEST ?
[Re: 1_WILD_RT]
#986711
05/07/11 10:18 PM
05/07/11 10:18 PM
72N96RR
I LOVE WEDGIES
I LOVE WEDGIES
Not allot of evaporation taking place on a zero degree day... This was much less of an issue when we had real gasoline... The needs of a carburated vehicle are not given an thought when blending the formulations used today...
You nailed it with the REAL GAS comment..
