Re: /6 Holley 390 jets
[Re: wings471]
#986604
05/05/11 02:50 PM
05/05/11 02:50 PM
Posts: 3,278 West Coast, USA
jbc426
West Coast, USA
The best way is to read your plugs or get a data logging wide band. FAST has a nice one for just over $400. It's portable so you can do a bunch of cars. Here's a good page on plug reading on FBO's website. http://www.4secondsflat.com/Spark_plug_reading.htmlMake sure your float level is set correctly. Also, did you shorten up the mechanical advance slots in the distributor? Slanty's like significantly more initial, but not more total ignition advance. The difference the distributor recurving makes in a slant is unbelievable. Are you still running points?
1970 Plymouth 'Cuda #'s 440-6(block in storage)currently 493" 6 pack, Shaker, 5 speed Passon, 4.10's 1968 Plymouth Barracuda Convertible 408 Magnum EFI with 4 speed automatic overdrive, 3800 stall lock-up converter and 4.30's (closest thing to an automatic 5 speed going)
[Re: jbc426]
#986605
05/05/11 03:11 PM
05/05/11 03:11 PM
Posts: 390 pacific northwest
wings471
pacific northwest
No. I have electronic ignition. The float level is good, a/f is one turn out and the pv is new.
[Re: wings471]
#986606
05/05/11 04:20 PM
05/05/11 04:20 PM
Posts: 5,746 Ontario, Canada
Dodgem
Ontario, Canada
stock is the best staring point found this R6299-1 4160 390 37-1539 37-933 6-506 122-50 34R9716-34 N/S N/S N/A 0.025
so if this it it 50's front and 34R9716-34 plate
another could be the old power valve is pooched R6895 4150 390 37-1536 37-933 6-504 122-50 122-62 N/S N/S 125-85 0.025
[Re: Dodgem]
#986607
05/05/11 04:30 PM
05/05/11 04:30 PM
Posts: 5,903 Athens, Greece
Pyper70
Athens, Greece
I added a second metering block kit (I believe its a gasket, fuel lines, power valve, jets, longer screws and the metering plate. I wanted better adjustment procedures out of it. I think I put a power valve block off in the secondary circuit. Its been a long while. My biggest concern for the slant and the 390 was the bog...I fiddled around with the primary cam, accelerator pump excessively...never could get rid of it...Start with stock jets and move up from there.
Family owned 1969 Charger R/T DualQuad 440/727/GVO/3.55s
