BRAKE TROUBLES #986442
05/05/11 09:50 AM
05/05/11 09:50 AM
SOUTH JERSEY
HEMIFRED Offline OP
HEMIFRED  Offline OP
SOUTH JERSEY
the Road Runner
all new Strange calipers and
bleed system to death no air.even had calipers off opened bleeder pointing up
problem is there's not much pedal.
It has as recommended 1.125 " bore Mopar master on frame rail and it has the correct residuals
If we pinch off any line to the wheel then BINGO we now have full pedal
A: funked up master cylinder
B: stuck residual
C: stuck caliper ( checked out all have some movement)
D: I haven't got a clue
I ELIMINATED MASTER SIZE OR LACK OF VOLUME
home of the
Sox and Martin Hemi Duster
Re: BRAKE TROUBLES [Re: HEMIFRED] #986443
05/05/11 10:23 AM
05/05/11 10:23 AM
Left Coast
BobR Offline
BobR  Offline
Left Coast
I'd start with the residual valves then go to the M/C.
Re: BRAKE TROUBLES [Re: BobR] #986444
05/05/11 10:26 AM
05/05/11 10:26 AM
Left Coast
BobR Offline
BobR  Offline
Left Coast
Also. What kind of fluid? Silicone fluid(Dot5) will cause this.
Re: BRAKE TROUBLES [Re: HEMIFRED] #986445
05/05/11 11:21 AM
05/05/11 11:21 AM
Az
Crizila Offline
Crizila  Offline
Az
Could you explain the entire system - how it's plumbed, dual master?, Assume master is lower than the calipers? using a porportioning valve?
Fastest 300
Re: BRAKE TROUBLES [Re: Crizila] #986446
05/05/11 11:35 AM
05/05/11 11:35 AM
Az
Crizila Offline
Crizila  Offline
Az
If you have excess pedal travel, you have excess fluid travel. Ether you are compressing air or the shoes/pads are pulling too far away from their stopping surfaces. Sounds like you eliminated the master as the problem. Are you sure the pedal is coming all the way back to uncover the compinsating ports in the master. Pushrod have some amount free play? Master outlets have check valves ( residual pressure valves ) in the outlets? - manditory if the master is mounted below the calipers / wheel cyls.
Fastest 300
Re: BRAKE TROUBLES [Re: Crizila] #986447
05/05/11 11:38 AM
05/05/11 11:38 AM
Cincinnati, Ohio
Challenger 1 Offline
Cincinnati, Ohio
If all of the above is checked and OK, then it is air in the system. It's real tough to get it all out in a new system.
Re: BRAKE TROUBLES [Re: Challenger 1] #986448
05/05/11 02:52 PM
05/05/11 02:52 PM
Indy
joshking440 Offline
Lunch is on me!
joshking440  Offline
Lunch is on me!
Indy
Being that Fred is probably using his old man cane to press the brake peddle, he may not have proper leverage on the pedal.
Re: BRAKE TROUBLES [Re: joshking440] #986449
05/05/11 03:10 PM
05/05/11 03:10 PM
Casco, MI
Savoy1964 Offline
Savoy1964  Offline
Casco, MI
Could the location of front and rear lines be mixed up?
2003 Dodge 3500 Diesel
1964 Plymouth Savoy White 2dr sdn. 512 stroked, Dominator, New Best 9.75 @ 138.50mph
2019 Challenger Scat Pack 1320 White Knuckle-K&N Cold air filter, Billit Oil catch can, drag radials stock 11.911 @ 114mph
Re: BRAKE TROUBLES [Re: joshking440] #986450
05/05/11 03:10 PM
05/05/11 03:10 PM
SOUTH JERSEY
HEMIFRED Offline OP
HEMIFRED  Offline OP
SOUTH JERSEY
If needed I have an appendage of my own that I can substitute for a cane
home of the
Re: BRAKE TROUBLES [Re: HEMIFRED] #986451
05/05/11 03:39 PM
05/05/11 03:39 PM
Q
Quicktree Offline
Quicktree  Offline
Q
you would be lucky to get past the seat much less reach the flooru
Re: BRAKE TROUBLES [Re: Quicktree] #986452
05/05/11 03:48 PM
05/05/11 03:48 PM
Eighty Four, PA
B G Racing Offline
B G Racing  Offline
Eighty Four, PA
Look for a bent caliper mounting bracket,uneven caliper to rotor alignment or possible loose rotor that has some movement.Sometimes one piston thats not holding tight pressure will keep air in the system.We had a Hemi Roadrunner that we couldn't get the brakes bled on and it turned out to be his wheel studs didn't allow the lugnuts to clamp the wheel and rotor tight.Another car had a bent caliper mount and did the same thing.It's worth checking.
Re: BRAKE TROUBLES [Re: HEMIFRED] #986453
05/05/11 04:20 PM
05/05/11 04:20 PM
U.S.
moparniac Offline
moparniac  Offline
U.S.
Fred I have new strange the whole way around... took quite a few tries at bleeding it to get air out to get a pedal in a whole new system! I used DOT4 I think thats what instructions called for... let it set a few days without touching the car and the pedal feel goes away till I pump them up again... Im gonna try bleeding some more.
Mopar Performance
Re: BRAKE TROUBLES [Re: B G Racing] #986454
05/05/11 04:22 PM
05/05/11 04:22 PM
SOUTH JERSEY
HEMIFRED Offline OP
HEMIFRED  Offline OP
SOUTH JERSEY
although many of the replies here have been tried there are some good suggestions also. I am not working on it but we decided to attack the master cylinder first . bleed it again or just swap it while there
home of the
Re: BRAKE TROUBLES [Re: HEMIFRED] #986455
05/05/11 05:24 PM
05/05/11 05:24 PM
sg66mopar Offline
sg66mopar  Offline
Fred, like most of us with your type of brake system I've been there - done that.
BG had some good info. Of course, if the whole system is new there "shouldn't" be any bent or worn parts.
More than once on mine I've had to put the car up REAL high on one end at a time and let it sit overnight to get all the air bubbles to migrate to the bleeders.
I've also noticed that the pedal will get better after the pads are bedded in.
Re: BRAKE TROUBLES [Re: sg66mopar] #986456
05/05/11 05:55 PM
05/05/11 05:55 PM
Sweet Home Alabama
MRMOPAR622 Offline
MRMOPAR622  Offline
Sweet Home Alabama
I just had some problems with my brakes. I started with plugging the master cylinder and working my way back till I found the right rear caliper was bad. I put seals in it & checked it from front-back and could not find what the problem was with it. The UPS man will be coming tomorrow.
I guess all I should have said was start at the master cylinder & work you way back blocking off everything till you find the problem. I used 2 cans off Wilwood Hi-Temp 570 not finding the problem before doing it that way. GOOD LUCK!!!
"To Be The Man'You Have Got To Beat The Man" "T/D and Pro-Bracket Racer"
Re: BRAKE TROUBLES [Re: HEMIFRED] #986457
05/05/11 06:18 PM
05/05/11 06:18 PM
Cincinnati, Ohio
Cincinnati, Ohio
Wish you were closer Fred, I come over and pressure bled them for you in a matter of minutes.
Re: BRAKE TROUBLES [Re: Quicktree] #986458
05/05/11 06:36 PM
05/05/11 06:36 PM
Lehigh Acres, Florida
rickstershemi Offline
and you know this.....how
Rickster
Re: BRAKE TROUBLES [Re: rickstershemi] #986459
05/05/11 06:47 PM
05/05/11 06:47 PM
Sydney,Australia
tex013 Offline
tex013  Offline
Sydney,Australia
you could try reverse flushing/bleeding the system.
i have had to do this on a few cars both brakes and clutch hydraulics.
yes it can be messy at the master cylinder
Tex
New best ET 10.259@129.65 .
New best MPH 130.32
Finally fitted a solid cam,
stepped it up a bit more
3690lbs through the mufflers
Power by Tex's Automotive
Re: BRAKE TROUBLES [Re: sg66mopar] #986460
05/05/11 07:36 PM
05/05/11 07:36 PM
Az
Crizila Offline
Crizila  Offline
Az
This is a good way to bleed a tempermental system. Done it lots of times. FWIW, if the peddle is low and spongy and you can pump it up = air in system. Peddle low, but hard at the end of its travel, shoes/pads are retracting too far or the master cyl dia is too small.
Fastest 300
Re: BRAKE TROUBLES [Re: Crizila] #986461
05/10/11 09:42 AM
05/10/11 09:42 AM
Sweet Home Alabama
MRMOPAR622 Offline
MRMOPAR622  Offline
Sweet Home Alabama
Mr HEMIFRED, have you found your problem yet? Mine is doing the same thing as yours. We even pressure bleed them,no air in system no pedal. When we get all the air out it feels like it has a pedal,but when you push it down to the floor it goes. New master cylinder,new hard line to the rear,new calipers(all Wilwood). I just replaced the 2 braided steel brake lines to the calipers,will bleed the system again this afternoon. I have been told the braided lines never go bad,but that is the only things I had not replaced yet. I have never run a residual valve on my dragster before,Wilwood says to have brakes I must have one. My understanding of a residual is if you do not have one the fluid can run back to the master cylinder and let the piston retract back into the calipers and you will have to pump the pedal a time or 2 to get the pedal back up. That's not my problem you can pump the pedal all day and they never hold. They are like yours block off any line and they hold.
Hope you have fixed your problem and can tell me the fix.
P.S. I am sure you check this also,with one of the lines unhooked to the caliper when you push the pedal to the floor how much brake fluid come out? Mine looks like about a teaspoon full comes out.
